Old 06-30-2015, 10:36 PM   #1
Bennyb
Drives: 2011 Camaro 2SS
Best Blower Cam
My lifters recently gave out and damaged my current cam which is the LG6x3. I chose this cam because originally I was going to FI my car which i did with the ECS 1500SL. I have to replace my cam and was wondering the best blower cam out there, also looking for a choppy one like the LG6x3. thanks in advance.
Bennyb is offline   Reply With Quote
Old 06-30-2015, 10:56 PM   #2
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Well I had that same cam in my car when I was NA. I am currently running a Dallas Performance blower cam. Brian Tooley also has some nice blower cams.
__________________________________________
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 06-30-2015, 11:02 PM   #3
Unreal
Drives: 2006 Z06
Tons of good choices. I always recommend contacting cam expert of your choice and having something spec'd for your needs. Pat G, Ed C, Brian T, Martin T, etc.
Nick
Corvette Z06 -1200ish rwhp
Old 06-30-2015, 11:19 PM   #4
Bennyb
Thanks. Will definitely be contacting one of them tomorrow.
Old 06-30-2015, 11:47 PM   #5
LSXBumblebee
LSX Bumblebee
LSXBumblebee's Avatar
Drives: 2014 LSX Camaro
Lots of good with BTR Stage 3 PD Cam
LSX 427 | ZL1 Driveline | LSA Blower | Stage 3 BTR PD Cam | 85 lb. Injectors | ZL1 Pump | ADM FPCM | Pulley
LSX Bowtie Block Blueprinted by Gilroy Automotive Machine | Assembled by LSXBumblebee/Arnold Crocker
Build Thread: LSX_Bumblebee's 2014 LSX Camaro 2SS/RS Convertible
LSXBumblebee is offline   Reply With Quote
Old 07-01-2015, 01:03 AM   #6
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
ill be going btr stage 3
Nighthawk89 is offline   Reply With Quote
Old 07-01-2015, 05:50 AM   #7
Bo White
Bo White's Avatar
I wouldnt run a "blower" cam on a centri.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 07-01-2015, 07:30 AM   #8
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I agree. There is no "best" cam in general terms. For a cam to work best it should be spec'd taking all details of your build into account. Since you are spending for a cam, at least have an expert help you get the best possible for you.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 07-01-2015, 10:58 AM   #9
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Do yourself a favor, here you go
Pat Guerra!!!!!
http://www.guerragroup.com/#!camshaft-help/c1mq5
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-01-2015, 11:18 AM   #10
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Gt9 on my current set up for hp.
Gt11 on my new 427 for tq
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 07-01-2015, 12:51 PM   #11
Ret Fuzz
Banned
Drives: 2010 Camaro
Love my stage 3 BTR
Ret Fuzz is offline   Reply With Quote
Old 07-02-2015, 07:06 PM   #12
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Feel free to give us a call. We would be happy to discuss a cam that would suit you best.
nick
Lethal Racing is offline   Reply With Quote
Old 07-03-2015, 10:55 AM   #13
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
The JRE rough idle small cam has run 9.80's@140 with a whipple.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
