Old 07-01-2015, 11:24 PM   #1
BUNNY15
BUNNY15's Avatar
Drives: 2010 Rally Yellow 2SS/RS 6M ~~ LSA
Ls3/LSA Conversion w/ NightFury Cam?
Does anyone here run a NighFury cam with their LSA conversion? Just wondering what kind of RWHP numbers it may put out on the Ls3 motor? 600, 630, 650, 700+??? I'm already considering my winter mods and I'm really leaning toward this.
---Tiffany, the car junkie
HALNSS
BUNNY15 is offline   Reply With Quote
Old 07-01-2015, 11:47 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Not the best cam for an LSA but it'll work
62nalide is offline   Reply With Quote
Old 07-01-2015, 11:51 PM   #3
BUNNY15
BUNNY15's Avatar
Suggestions?
HALNSS
Old 07-01-2015, 11:57 PM   #4
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
I was planning on this too
camarosspower is offline   Reply With Quote
Old 07-02-2015, 12:02 AM   #5
LSXDoc
LSXDoc's Avatar
Drives: 2015 1SS/RS/1LE
Lethal makes a 115lsa Nightfury for supercharged applications, that was my plan too!
2015 Red Hot 1SS/RS/1LE
ADM LSA kit
BTR Stg3 PD Cam
Stainless Power LTs w/ CATs
Stainless Works ZL1 Res. Delete 3" Retro Catback
DST Ported ZL1 TB
619RWHP / 539LB-FT
LSXDoc is offline   Reply With Quote
Old 07-02-2015, 12:51 AM   #6
BUNNY15
BUNNY15's Avatar
But does anyone know the numbers we can expect to see?
HALNSS
Old 07-02-2015, 02:40 AM   #7
forklord
forklord's Avatar
Drives: 2010 2SS
there are so many options out there...do you want drivability? pure peak power? i suggest asking your tuner if they have a clue... get a custom grind cam motion cam...low lash solid roller if you wanna spend the extra. who gives a shit about hte nightfury cam. thats not how cams works. you want the right specs for your needs/application. this whole off the shelf cam business is hilarious
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 07-02-2015, 09:43 AM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by BUNNY15 View Post
Suggestions?
Your in Dallas dude there's dozen shops who can spec you a cam.
ADM did a GT9 can on my buddy he made 689rwhp 627rwtq on it through an auto.
Old 07-02-2015, 10:18 AM   #9
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Gt9 on my current setup.
Gt11 on my 427 setup next week
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 07-02-2015, 10:23 AM   #10
BUNNY15
BUNNY15's Avatar
Yea I'm well aware that I can get a custom grind, but that wasn't my question. I have a NF which is why I specifically asked about NF In my original post. I didn't ask about driveability because mine is not a daily driver, but I do enjoy driving it when the weather is right. Originally, I was just curious about RWHP.
HALNSS
Old 07-02-2015, 10:32 AM   #11
Scuzz
Scuzz's Avatar
Between 600-700. All your supporting mods, what dyno you use, weather conditions on that day, what Pullies you run, all is going to tweak the numbers a little. And fuel, can't forget fuel.
On my LSA blower I was 660 Rwhp on a auto
Old 07-02-2015, 10:43 AM   #12
BUNNY15
BUNNY15's Avatar
Thank you.
HALNSS
Old 07-02-2015, 01:14 PM   #13
camarosspower
I don't have any issues with driveability on the nf cam. I daily drive mine
Old 07-02-2015, 01:29 PM   #14
Unreal
Drives: 2006 Z06
Fuel, and pulley size on blower will dictate what power you make, not cam choice as much. I see no reason to run a cam like that on a blower car. My cam is small on a 427 blower setup and makes 1200rwhp. I don't see a need to overcame a FI car. Let the blower do the work and pair a cam for good efficiency and power band.
Nick
Corvette Z06 -1200ish rwhp
