Old 07-03-2015, 08:59 AM   #1
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
Road course camber setup
Between the difference of running autoX and a road course, is there a happy medium for front and rear camber or do these cars like more negative camber on the road course? I am ready to run the NCM event in BGK and needing to know if I need to plan any "wrench time" in between the road course and the autoX events. I would prefer to have the best alignment setup for autoX and tweak it for the road course if needed.
Currently run about -1.2 camber in the rear and -2.5 in the front. Rear toe in is slight and front toe is zero to maybe 1/16 toe out. Front caster is about 7.6.
Zombie killer is offline   Reply With Quote
Old 07-03-2015, 10:23 AM   #2
SPCBA
Drives: pleather and Chiclets
http://www.camaro5.com/forums/forumdisplay.php?f=219
You might even find someone who has a set up for your track if you ask there.
SPCBA is offline   Reply With Quote
Old 07-03-2015, 10:44 AM   #3
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I think your set up will work as it is for the road course. Tire pressures may need to be adjusted.
LMS Engineering
White_SS/RS is offline   Reply With Quote
