07-03-2015, 08:55 PM | #1 |
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
Input/Opinion wanted on clutch problem
Hi guys, I've been beating on my car pretty regularly and it still has the factory clutch in it. Last night the clutch went to the floor on the 1-2 shift and didn't return until I kicked it a few times.
After it came back up, it seems like the clutch is making a lot of noise (chatter while engaged that stops immediately on disengage). I know a lot of us have fought this battle before, but what was your winning move? Better clutch? Upgrade the slave? Return spring? It is engaging normally today under light throttle, and did drive back home last night. It just seems to be making more noise (could be my imagination/worry talking there though).
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading... |
07-03-2015, 09:04 PM | #2 |
Tri-County Camaro SWFL
Well my win was the LPE return spring. But that's really a Band-Aid solution for the real problem. Upgrade the slave and while your at it, upgrade to a billet throw out bearing.
07-04-2015, 01:49 PM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
If your cammed/sprayed and beat on it your stock clutch will not hold up very long. Only real fix is a new aftermarket clutch. And while your in there might as well do a tick speed bleeder and a separate clutch fluid reservoir.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
07-05-2015, 12:14 PM | #4 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
07-05-2015, 01:28 PM | #5 |
Thanks guys. Pricing parts from sponsors now.
2011 Camaro 1SS
07-05-2015, 07:54 PM | #6 | |
Thanks for the help, Ill need this soon I'm sure of.
08-21-2015, 02:21 PM | #7 |
Dstrong34
Drives: 2013 Camaro SS Join Date: Aug 2015
How hard is it to replace the plastic bearing support with the Monster Billet support?
08-27-2015, 12:54 PM | #8 | |
In The Circle
