Old 07-04-2015, 12:31 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Exclamation Help on installing bmr toe rods
I'm really thinking about purchasing the BMR toe rods. I know they have the instructions online but does anyone have a DIY write up on how to lower the subframe? Also how difficult is this install? Any help would be appreciated!
booneSS13 is offline   Reply With Quote
Old 07-05-2015, 12:46 AM   #2
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
I don't know if these will help,
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 07-05-2015, 08:36 AM   #3
booneSS13
booneSS13's Avatar
Thanks a lot but the problem with those is they don't show the process where you have to lower the subframe and how it's actually done
Old 07-05-2015, 10:40 AM   #4
DARK AGE 53
Drives: 2010 SS
I'm not really familiar with the 5th Camaro suspension, that being said I guess I don't understand why you need to lower the rear sub-frame to install those rods?
Looking at the Lakewood video the only thing I see is you need to mark is the eccentric washer position, everything else looks like you just unbolt and replace.
Old 07-05-2015, 11:32 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
According to BMR instructions you need to loosen the front and rear bolts to access the drivers side bolt because of the fuel tank. The videos only show passenger side installation.
Old 07-05-2015, 01:11 PM   #6
DARK AGE 53
Drives: 2010 SS
Got it now, found the BMR PDF install of toe rods.
[BbooneSS13][/B], from what I see if you have a lift it would be a fairly easy install, you can obviously do it with a lift though. I have a lift and all the tools to do this install, if you live in the central Michigan area I'd be happy to help.
Old 07-05-2015, 01:55 PM   #7
booneSS13
booneSS13's Avatar
Thanks a lot I really appreciate it I wish I was still in Michigan I used to live in South eastern michigan I'm in Iowa now. That's a blessing you have a lift I wish I had one. I need to see how to do it on floor Jacks if I'm not mistaken there's just 4 bolts for the cradle but that I'm not sure of
Old 07-05-2015, 03:05 PM   #8
DARK AGE 53
Drives: 2010 SS
The instructions show to remove the two front bolts and loosen the two rear bolts, you've probably have already seen this but if not http://www.bmrsuspension.com/siteart/install/TR002.pdf .
Old 08-18-2015, 07:44 PM   #9
allshotout
allshotout's Avatar
Drives: 2014 SS Camaro
not bad to do at all. Passenger side doesn't require anything, driver side you need to lower sub frame about 1/2 inch for bolt to clear fuel tank. I used floor jacks and another jack on rear end housing with 2x4. I have a mid rise lift, but felt it was easier to manage the lowering of subframe on the ground.
allshotout is offline   Reply With Quote
install, rear, subframe, toe rods
