![]() ![]() ![]() ![]() ![]() Drives: 14 1LE Join Date: Mar 2013
ZL1 and Z06 Rotors
The ZL1 and the C7 Z06 (non CCB) have the same rotor diameter and thickness, 14.6"/1.3" They also generally look the same other than the Z06 being slotted. Both also seem to use the same construction method (aluminum hat riveted to the cast iron rotor). Has anyone compared them side by side or know specificaly if there's any difference in hat offset?
LMS Engineering
![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
different rotors. Studs are smaller od on z06. Also, z06 rotor is post pillar and significantly lower thickness plates. Could crack on our applicatios.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
