![]() Drives: 2014 2SS RS 1LE Ashen Gray Metalic Join Date: Mar 2015
2014 1le ls7 cam, ported heads, long tubes.
Hello everyone, I just ordered a few mods, I purchaced the cnc ported head and ls7 cam kit straight from gm, along with kooks long tube headers and hiflow cats, parts plus shipping I ended up paying about $3300 for everything, after labor and tune ill be around $5000, it will be finished by august 20th and ill have the dyno numbers for anyone who is interested!
Drives: 2015 Redhot 1LE Join Date: Feb 2013
5k? why not save up a bit more and go with a supercharger
War Horse Pilot
Can't wait to see what the LS7 cam nets.
I have enough to go supercharger, even after these mods, but I like the thought of, alot of power with a naturally aspirated engine. I saw another 1le with similar mods dyno at 527 to the wheels, i havent seen many supercharger systems offer over 600 rwhp without supporting mods.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Not looking to start a fire storm , but if a 427 LS7 is good for 505 hp at the flywheel ( 475 rwhp )how can a 376 with a LS7 cam make 527 to the rear wheels ? Your numbers are way too optimistic . And IMHO there are a lot better cams out there to make big power . As far as I know LS7 heads are cnc ported too .
OLD GUY FLYING FAST AND LOW
#6 | |
#7 |
![]() Drives: 2015 1LE Join Date: Nov 2013
Good luck.....please don't get your hopes up as I thought Chevy claims that the heads and cam are worth about 40hp..,(not 100% sure) 500rwhp is a lot for a na ls3. I bet 475ish rwhp when all is said and done. The highest hp na 1le I've seen is this one:http://www.camaro5.com/forums/showthread.php?t=411837 and the mods to it are not your common heads/ cam supporting mods car.
No matter what I'm sure it will run strong and it will be enjoyable but don't set your expectations too high because I've seen more then one dyno crush a person's ego or expectations. Last edited by yenkostyle; 07-07-2015 at 08:30 PM. |
#8 | |
![]() ![]() Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
#9 |
I'm entertaining this option. I was looking at twin turbos, but that is off the table. Im wanting to run a sustained speed of 150 MPH for Silvetstate. I talked with RMS here in Calif. about doing my heads, a cam, headers and a tune. They said 500 RWHP is in the ballpark.
#10 |
![]() Drives: Camaro ss 1le Join Date: Jan 2014
Good luck and Lsa conversion will get you way past 600 rwhp mark
#11 |
![]() ![]() Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
Not everybody wants the power of forced induction. Harsh torque curves are harder to manage on a twisty track or road course. The extra weight in general is again, a minus for anyone, but especially for anyone that want's to do more than just go fast straight.
It also produces power that puts strain to the limits of several other components on the car, namely clutch, diff, and halfshafts, but also on everything else. Even if people claim the bottom end can handle 700, 800, 900hp doesn't mean it was built to do so. To truly, reliably run much more than 550-600 rwhp is going to cost way more than that $6-7k supercharger or $8k turbo 'bolt on' kit cost. I'd say that you have to just about double that cost. Some people want that loppy, rough, mean idle and power curve that the right cam provides. And some of us don't want to have to go into the trans, rear end, fuel tank, etc. to gain more power.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. Last edited by Bodywerks; 07-08-2015 at 06:00 AM. |
#12 | |
My guess, is you'll be more in the 460rwhp area...
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
#13 |
![]() Drives: 14 1Le --14 chevy ss sedan 07shelby Join Date: Sep 2014
no disrespect but that set up is going to be a big disapointment if you expect 527rwhp out of it ...and definatly don't dyno it on a load bearing dyno or your really gonna feel bad ..i have a decent setup with a much bigger cam and i make 484 434 on a mustang dyno ..good luck
a 427 with ls7 heads and ls7 cam make about 445-460 rwhp so doing that setup on a 376 is gonna be lower wouldn't you think !!! |
#14 | |||
| Tags |
| 1le, cam, ls7 |
