Old 07-07-2015, 08:29 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
pcv/catch can setup for new turbo system
just bought an on3 turbo kit with lots of upgraded goodies...i used to have an eforce and i just had two regular elite engineering catch cans for each valve covers vent line. when i removed my supercharger i couldnt get the edelbrock valley plate off so i said screw it and left it. same for catch can setup now that im n/a. i noticed im leaking a little tiny bit of oil sometimes and wondering if its my rear main seal due to 11psi of hard driving. or maybe just due to the service bulletin they had on hte early camaros.... either way, i want to make sure i do it right with the single turbo this time. need to get the right parts together. any tips? do i need to put the stock valley plate on to get the extra port which isnt on the edelbrock plate? vented catch cans? oil seperator? vented oil fill cap? probly be runnin 10-15 psi for sure
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 07-07-2015, 08:45 PM   #2
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
I use a mighty mouse catch can and I do believe he said the vally plate was the least restrictive and best to use
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 07-07-2015, 10:33 PM   #3
forklord
forklord's Avatar
Drives: 2010 2SS
whats you hp/tq?
Old 07-07-2015, 10:42 PM   #4
Unreal
Drives: 2006 Z06
Call Dave@mightmouse. I run a single one of his cans. Best setup I've had. Had elite, had RX, had others. MM is by far the best.
Nick
Corvette Z06 -1200ish rwhp
Old 07-08-2015, 06:05 AM   #5
'14-ELLIE
'14-ELLIE's Avatar
Drives: 2015 2SS/RS 1LE
I have the MM also with zero complaints. Dave is a great guy. Give him a call!
'14-ELLIE is offline   Reply With Quote
Old 07-08-2015, 06:47 AM   #6
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Mighty Mouse cans here also.... I don't use the valley plate port.... not needed.
Speak to Dave.......anything else a waste of time and money imo.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 07-08-2015, 12:24 PM   #7
AITI
Drives: 2015 LFX Auto
The key to proper evacuation for a turbo application requires 2 sources of evacuation vacuum as the intake manifold becomes pressurized when in boost. The MM can releases pressure to the atmosphere, illegal in all 50 States on the street, and is then messing with fuel trims as all the air is not metered. Call or email Steve from Elite Engineering and he can instruct you on the proper way to address this issue. You won't regret it. Also, Elite is a supporting vendor on this site, MM just coasts off all those that plug him for free (as the moderators allow this so what reason should any pay each month when others are allowed to advertise free?). Support those that support the site IMHO.
AITI is offline   Reply With Quote
Old 07-08-2015, 12:27 PM   #8
realcanuk
realcanuk's Avatar
All I can say is.... nothing.....
If you think being a sponsor, means a better product.... good luck to you.
Old 07-08-2015, 12:54 PM   #9
Unreal
Drives: 2006 Z06
He isn't even close to correct and is plain wrong on almost everything he said. Not worth even addressing someone that is so wrong.
Anyways, I've used the others, MM is the best. He gets plugged because the quality and performance of his product is top notch.
Nick
Old 07-08-2015, 12:56 PM   #10
z3R0fo01
z3R0fo01's Avatar
Drives: 2014 1SS RS 1LE tvs2300
You sir, are very misinformed.
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned
z3R0fo01 is offline   Reply With Quote
Old 07-08-2015, 01:01 PM   #11
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Same here, tried them all and only the MM can worked for me.
Old 07-08-2015, 01:13 PM   #12
z3R0fo01
z3R0fo01's Avatar
I guess we should clear this up really quickly. The MM has different options and none of them let un metered air into the engine. Turbo and centris require a more complicated catch can than a pd, and MM seems to have this pretty well figured out.
Elite makes an excellent catch can. I have one. I had an Apex before my supercharger and it was also top notch. I went to the elite because it was smaller and easier to mount not he driver's side. And to be honest I really like the anodized blue. I was going to try out the MM, but it is a large can, and like I said I only needed a simple setup. I did contact MM and he promptly answered my questions.
Also, supporting vendors is always good, but to put someone down because they have a product that works is beyond asinine. He has a good reputation because he has a product that works and people like to do business with him.
Anyways, I was not even going to respond, but I figured I would help to clear things up.
JRE tuned
Old 07-08-2015, 01:35 PM   #13
realcanuk
realcanuk's Avatar
Was going to say the same thing about being wrong on most points, but couldn't be bothered. He has an Elite... so its the best...
Old 07-08-2015, 06:05 PM   #14
'14-ELLIE
'14-ELLIE's Avatar
This is a situation where I laughed, but then I stopped laughing because I was so damn confused. And now I'm laughing again because I had to read it a second time. Did not know the MM cans were also a BOV! Now I'm even happier I have one.
