Old 07-07-2015, 11:00 PM   #1
Airmaster
Go Gators!
Airmaster's Avatar
Drives: Camaro Jeep Abarth 944 325i
Question Do I need new Rear Lwr Cntrl Arms??
Hello everyone, I am leaning towards going with a JPSS rear sway bar as it will clear my V6 rear calipers. I realize I need the FE4 rear end links but do I need the rear lower control arms too???
I looked under my car and it looks like I already have the FE4 style rear lower control arms and there is even a hole in place for the end link to go through. Don't have pics but I can provide them if needed!
Appreciate any help! My V6 is a 2013 MY btw.
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts
Engine Mods: All bolt ons (haha)
Brake Mods: Brembo SS caliper swap front and rear
Airmaster is offline   Reply With Quote
Old 07-08-2015, 09:47 AM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
You should already have FE4 control arms even if you have the FE3/2 sway bar.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-08-2015, 03:28 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
+1 Yes you've already got the correct LCA's.
JPSS will include the endlinks with your bar. I found it helpful to jack up the car, place it on jackstands and remove both back wheels.
Take out the old bar/endlinks and put the new endlinks in place (just stick'em up thru the holes). Then lower the car down a bit on blocks under the ends of your LCA's (so the rear suspension is under load). A piece of 2X4 wood is the right width and will protect the paint.
Now slide the new bar into place with the black straps finger tight and the bar will drop right into place on top of the endlinks. Tighten everything to spec, replace the wheels and your're ready for a cold one!
Now if you want to save $100+shipping costs look here- http://www.camaro5.com/forums/showthread.php?t=414288
No it's not quite as stiff as the JPSS, but it's a big improvement over any other FE3 bar!
Old 07-08-2015, 09:48 PM   #4
Airmaster
Go Gators!
Airmaster's Avatar
Awesome thanks. And thanks for the offer on the Pfadt bar, but I'm all wound up on getting this JPSS bar now haha.
