Old 07-08-2015, 11:02 AM   #1
BamaRocker
Drives: 45th Anniversary owner and 72 Camar
service brake assist....WTF
Well go to start car and head to work and this happens.." service brake assist ". Car starts then shuts right off.
Now what do i do.
BamaRocker is offline   Reply With Quote
Old 07-09-2015, 10:34 AM   #2
BamaRocker
All is good, just as I hoped it would be. The Range Technologies AFM unit was throwing codes...I forgot and left it in overnight which is something I never do because of battery drain. For some reason it would not let the car reset..Left it unplugged all day and everything is back to normal.
Old 07-09-2015, 10:54 AM   #3
1BadAssSS
Drives: 2018 ZL1 A10
Glad you got it figured out neighbor!
1BadAssSS is offline   Reply With Quote
Old 07-09-2015, 01:50 PM   #4
BamaRocker
Old 07-09-2015, 03:03 PM   #5
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
Weird, I have never unplugged my range device in over a year. Never had a problem.
Rainbow1616 is offline   Reply With Quote
Old 07-09-2015, 03:22 PM   #6
pony
pony's Avatar
Drives: 2011 2SS Convert; Color RJT
Same thing here, only "service park assist". Unplug Range and all is good.
pony is offline   Reply With Quote
Old 09-05-2015, 11:19 PM   #7
imnuts
imnuts's Avatar
Drives: 2011 2SS/RS convertible
I too just has the same issue. I have never unplugged my range. bit I sure will now. Boy that was a scaring issue.
imnuts is offline   Reply With Quote
Old 09-05-2015, 11:54 PM   #8
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
That's why you should get a tune to get rid of the afm haha
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
