Old 07-10-2015, 01:36 PM   #1
1LEdabeast1LE
Nic@Night
1LEdabeast1LE's Avatar
Drives: 2015 Camaro 1SS/RS 1LE
Angry Klunking when decelerating under 2k rpm's. BRAND NEW CAR!
VERY noticeable klunking sound when engaging the clutch (pressing it in) and decelerating under 2,000rpm's. Was told by the dealer that this is drive-line slack? This is very loud and extremely annoying! Anyone had or have this issue?
I appreciate any advice that will help me figure this out.
Thanks.
1LEdabeast1LE is offline   Reply With Quote
Old 07-10-2015, 01:39 PM   #2
arkentect
arkentect's Avatar
Drives: 2010 Camaro SGM 1LT M6
Thanks.
Yeah I get the same thing if I press the clutch in fast at slow speeds. You'll get used to how to avoid it the longer you drive the car
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD
Current - 2009 C6 Corvette Z51
arkentect is offline   Reply With Quote
Old 07-10-2015, 01:43 PM   #3
mdub76
mdub76's Avatar
Drives: 2010 2ss/RS IOM GFX M6
They have been doing it since 2009. It's normal.
mdub76 is offline   Reply With Quote
Old 07-10-2015, 01:46 PM   #4
ChocoTaco369
145lb Powerlifter
ChocoTaco369's Avatar
Drives: 2013 Camaro 2SS RS LS3
The only time that happens is when you jam the clutch in hard at low speeds when the car is practically chattering and the tranny is cold. If you're in the proper gear and the engine/transmission is warmed up I've never had it do that. I don't think it is a problem. Clearances expand once the car's warm and it goes away.
ChocoTaco369 is offline   Reply With Quote
Old 07-10-2015, 01:47 PM   #5
thegreatwhite
Drives: 2014 SS
ya i have the same thing when decelerating or accelerating at a certain rate then i engage the clutch, pretty much around low RPMs. i think its a normal thing for the SS cause iv read more convos on here about the same thing an they say its normal for this transmission. doesnt sound normal though since it happens when you engage the clutch it sounds like the clutch is bouncing off something or somethin metal is getting knocked around, idk hard to explain.
thegreatwhite is offline   Reply With Quote
Old 07-10-2015, 01:48 PM   #6
1LEdabeast1LE
Nic@Night
How can that be normal? 6 years, and no one has figured out a way to fix it? I can only turn the radio up so loud, haha
Old 07-10-2015, 02:00 PM   #7
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
At low speeds such as parking in your garage, it has some "clak, clak, clak" sound.
I went to the dealer and said it was some tolerance thing and it was "normal".
JLSuperfly is offline   Reply With Quote
Old 07-10-2015, 02:08 PM   #8
krazzyk01
Liv'n The Dream!
krazzyk01's Avatar
Drives: 2013 Black 2SS RS 1LE
There's another thing that makes this noise. I know the clackity clack y'all are talking about and yes, that is partly normal. My 1LE went into the shop and they found the rear axle bolts were VERY loose! I wanted them to replace the bolts but they told me GM would only pay for them to tighten them up. Have a nice day, let your next car be an import.
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
krazzyk01 is offline   Reply With Quote
Old 07-10-2015, 02:29 PM   #9
movurazz
movurazz's Avatar
Drives: 2015 1LT Coupe
I have a 2015 1LT and get the same thing. I have noticed that if I keep my foot on the gas just a little to keep the RPMs up it does not make the noise. There ya go problem solved burn all your gas up to keep it quiet. haha Stupid I know but it doesn't sound like the rear end is going drop out.
movurazz is offline   Reply With Quote
Old 07-10-2015, 02:32 PM   #10
vinman
The BBOMG fill-in husband
vinman's Avatar
I can't hear shit over the sweet sound of the npp
UPSTATE C5 MEMBER
Old 07-10-2015, 02:33 PM   #11
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I do think that a main result of the this is lugging the engine. Keeping the RPM's up should help with this, at least it seems it does with our car.
gajagfan is offline   Reply With Quote
Old 07-10-2015, 02:43 PM   #12
Stealthpanda
Thread Ender
Stealthpanda's Avatar
Drives: 2010 Camaro 2SS/RS L99
Isn't that driveline shunt? Or am I thinking of something else?
Stealthpanda is offline   Reply With Quote
Old 07-10-2015, 03:18 PM   #13
hazy
Drives: 2011 2SS/RS
I presume you would've said if you were hearing it upon acceleration too, but I had something similar occurring and it turned out to be a busted motor mount.
hazy is offline   Reply With Quote
Old 07-10-2015, 03:25 PM   #14
Drumminxx
Drumminxx's Avatar
Drives: 2014 2SS RS 1LE
Mine does it too. Usually in a parking lot. The dealer told me it was normal and the vette's do it too.
Nice car bro!
Drumminxx is offline   Reply With Quote
clutch noise, issue
