Drives: 2013 Camaro SS and 2016 Camaro SS Join Date: Jun 2014
Hurst Roll Control Kits for 2010-2015 Camaro
Hurst Part #5671518
![]() Application: Fits 2010-2015 Chevrolet Camaro Description: Designed with simplicity and ease-of-install in mind, Hurst’s complete Roll Control kits use the absolute best quality, pre-bent, double-walled, stainless steel brake line(s). In many cases, these hard-lines are superior to OEM quality. Hurst engineers realized when developing these kits that less is really more. Fewer connection points means fewer places where the system can leak and shorter lines mean less time bleeding the system. These kits are direct bolt-in meaning no measuring, no cutting, and no pre-bending; just simple, clean, factory-looking installs right out of the box. With easy, step-by-step instructions, you’ll be blessing the world with thick smoky burnouts and launching like a pro in no time. Used primarily in drag racing to provide positive locking action to the front wheels of racecars, reducing the chance of “Rolling the Lights” and producing more effective burnouts for heating up the tires. Rigorous testing has proved a 1/100,000 of a second release time and vibration tests have seen up to 30 Gs applied without mechanical failure. Adaptable to most domestic and import hydraulic brake systems. CAUTION: Hurst Roll Control should not be used as an emergency brake, or any application requiring the solenoid to be activated for a long period of time. Features and Benefits: -Advanced stainless steel valve assembly for ultimate corrosion resistance -Field-serviceable for cleaning or rebuilding to original factory specifications -Fully-enclosed epoxy-molded electrical coil for reliability -Attractive, finned-aluminum housing helps dissipate heat -Wider, lightweight base provides better mounting stability -150-micron screen filtered ports to prevent contamination -Extra threaded port for separate bleeder or brake line pressure gauge For additional questions, please call our Tech Line at 707-544-4761. Last edited by HurstPerformance; 12-11-2015 at 03:10 PM. Reason: Updated Fitment Info for 2010-2015 Models |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Looking into this setup very soon.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
![]() ![]() Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
Is there is a kit for 13-15 Camaros?
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
We have fit-up Hurst part #5671518 onto our 2013 Camaro SS, but we have yet to fully test it. Most likely these kits will fit all the way through 2015 but we need to complete testing and evaluation to be absolutely certain. This should happen over the next few weeks. |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Worked fine on my 13 Vert. Install was easy bleeding lines was hardest part.
Works great and doesn't throw any codes at all.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
#6 |
#7 |
It would be cool if you could use one on the brakes, one on the clutch and a two step. That would launch an m6 real good.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
I have my two step hooked to the arming switch of the line lock along with a pedal position switch on the clutch. Works great.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
#9 |
#10 |
![]() Drives: 2010 SS A6 Vortech, 3200 Stall 3.73 Join Date: Aug 2014
Love this kit. Agreed, bleeding the brakes was the hardest part. the arming switch fits nicely in the cigarette lighter hole (and take power from). Bought a shift knob from CFD that has the momentary in it. Very stealth, no extra holes. I have a reputation for doing John Force style burn outs now.
#11 | |
#12 |
We have confirmed that the existing Hurst Roll Control kit for the 2010+ Camaro, part #5671518 will carry on through the 2015 model year for the same sub-model configurations as previously listed.
#13 |
Will this work with the WOT Box? http://n2mb.com/wotbox
#14 | |
Drives: 2016 Camaro SS Join Date: Nov 2015
| Tags |
| burnout, drag racing, hurst, launch, roll control |
