Old 07-10-2015, 05:38 PM   #1
AJG87
Roc'd Out
Drives: Camaro
WTB: OEM Fuel Rail
Please PM with availability!
Thank you!
AJG87 is offline   Reply With Quote
Old 02-01-2018, 01:21 PM   #2
AJG87
Roc'd Out
Drives: Camaro
Bump! Please PM!
Old 02-07-2018, 03:26 PM   #3
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Originally Posted by AJG87 View Post
Bump!
I got one. Pm me
BFASTNOTLAST is offline   Reply With Quote
Old 02-16-2018, 07:58 AM   #4
AJG87
Roc'd Out
Drives: Camaro
Bump!
Old 02-17-2018, 10:53 PM   #5
hennesseycamaro11
hennesseycamaro11's Avatar
Drives: 2020 RGM ZL1 1LE
Pm’d
2020 Camaro ZL1 1LE Rally Green Metallic
2010 Camaro 2SS/RS (Gone but never forgotten)
-FAST LSXR 102 -Vortech V3 SI Supercharger -Pulleys -Shake N Bake Cam (233/248) -ALKY meth injection -TSP 1-7/8” headers -Catless X pipe -NPP w/ M2W -Eibach Coilovers -22" Dub S116 Wheels -Fesler Aero Package -3M matte black wrap
hennesseycamaro11 is offline   Reply With Quote
Old 05-07-2021, 09:35 AM   #6
AJG87
Roc'd Out
Drives: Camaro
Bump.
Old 05-07-2021, 09:56 PM   #7
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
I have the 1 that came off my 12 ss/rs
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 05-10-2021, 08:43 AM   #8
Tarendor
Tarendor's Avatar
Pics of the rail and optional -6an adaptor
Here are some pics that you asked for in PM.
Old 05-10-2021, 01:40 PM   #9
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
I just sent him one Friday. Need more?
joshnmn is offline   Reply With Quote
Old 05-10-2021, 01:49 PM   #10
AJG87
Roc'd Out
Drives: Camaro
Yes, interested in more.
Still awaiting UPS to drop yours off Josh.
Old 07-04-2021, 02:06 PM   #11
AJG87
Roc'd Out
Drives: Camaro
Bump.
Old 07-31-2021, 08:51 AM   #12
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Im pretty sure I have 2 new ones in the shop somewhere. Shoot me a PM if you want them.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
