Old 07-14-2015, 05:56 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Need air bag help ASAP.
I have a 2014 camaro ss. I ordered new racing seats and well they don't have air bags in them. How do I keep the air bag light off when I remove my factory seats?
If I need to order something where can I get it?
If I can jump wires with a resistor what size/type of resistor and what wires? Pictures would be great
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 07-14-2015, 07:01 AM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
I dont think the car will even start when those wire harnesses are unplugged, so you'll need to jump them somehow.
POWERFREAK is offline   Reply With Quote
Old 07-14-2015, 07:07 AM   #3
phillip123hastings
Drives: A real beast
Try ignoring the lights Just kidding.
Some guys used this on another forum, they were pretty satisfied.
phillip123hastings is offline   Reply With Quote
Old 07-14-2015, 11:19 AM   #4
2010_camaro
I don't see anything on that site.
Old 07-14-2015, 11:42 AM   #5
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
This link should help you.
http://www.camaro5.com/forums/showthread.php?t=277732
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
Old 07-14-2015, 11:57 AM   #6
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
the side seat airbag firing circuits are 2 wires. to turn off the light you need to bridge these wires with a 2 ohm resistor. DO SO AT YOUR OWN RISK.
maddoggyusa is offline   Reply With Quote
Old 07-14-2015, 12:12 PM   #7
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
So are the only air bag system compatible racing seats the stock Recaros?
gajagfan is offline   Reply With Quote
Old 07-14-2015, 06:29 PM   #8
SixSpeeder
SixSpeeder's Avatar
Drives: 2015 Camaro SS
That's not true, at least on my 2015 Camaro SS. There will just be a light on the dash and warning message.
2015 Summit White Camaro 1SS 6-Speed: NPP Exhaust, RS Package, Short Shifter, Nav
SixSpeeder is offline   Reply With Quote
Old 07-14-2015, 07:16 PM   #9
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Just a heads up on switching up the seats. I read on another thread that the passenger side airbag is activated when the sensor inside the seat bottom is activated, usually when someone sits on it (I know that's how it is on my Silverado, not 100% sure on the camaro). If you jump the airbag sensor on the passenger side, that airbag is always going to be off so if you have a passenger and you get in an accident, the airbag on the passenger side will never deploy. Just another thing to think about. If your just replacing the driver's seat then no issues there.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 07-15-2015, 03:42 AM   #10
2010_camaro
I don't care about the passenger air bag. I just want the light and messages off.
Old 07-15-2015, 07:25 AM   #11
POWERFREAK
I.AM.
POWERFREAK's Avatar
Weird, it must jave changed from the "older" ones.
Old 07-15-2015, 09:03 AM   #12
760bowtie
760bowtie's Avatar
In that case, you're good to go with the driver's side. What seats did you buy? Make sure to post some pics when you have them installed.
Old 07-17-2015, 12:56 PM   #13
2010_camaro
I can't install them untill i figure out this air bag light.
Old 07-17-2015, 05:54 PM   #14
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
The problem you'll have if you don't remove the fault, is none of the air bags will go off. So if you drive on the street, not a good idea. I was unlucky enough to pop my side curtains a few years ago. It is surprising how little information there is on this topic. I don't know if people just don't know, or not willing to share because of liability. Google for air bag simulators. Somebody made a device to fool the SIR/SDM in thinking the air bags were still in place. I've yet to hear whether that worked on the 5thG Camaro though.
bannonm is offline   Reply With Quote
