Old 07-14-2015, 05:02 PM   #1
jmp7624
Drives: 2012 camaro lt
2012 3.6l camaro lt ecu help
Okay so I have been searching all over the internet for help with this and I cant find anything helpful. I purchased a jet performance chip that plugs into the ecu and while installing a wire on the ecu busted. The car wouldnt start and found out the problem so temporarily I put a wire in its place so I could start the car. I dont have the Module chip in the car anymore. So I have to buy a new ECU but I cannot find one that came out of a camaro. They all come out of Impalas so if I buy one I will need to have it reflashed. Dealerships arnt really helpful here so I was wondering if anyone knows how much it would be and if I can do it myself. I was thinking about buying a performance tuner to reflash it but didnt know if I could get it to work.
jmp7624 is offline   Reply With Quote
Old 07-14-2015, 06:48 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
FYI, "performance chips" don't work they are a waste of money. As far as I know only a dealership can program the ECU for you.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
2012, camaro, ecu, how to, reflash
