Old 07-14-2015, 10:35 PM   #1
Laz
Laz's Avatar
Drives: 2011 Camaro 2SS/RS
How to fix P025A Code
Actually I got a couple of codes when I got a diagnostic check at Auto Zone. That was just the first one. The guy there told me that usually once I take care of the first one it will take care of all the others. So I'll start here.
Can someone tell me what is it, how to fix it, and approximately how much it would cost either myself or at the dealership.
The other codes I got in order were: P0174, P0230, and P069E.
Thanks in advance for all your comments and advise.
Laz is offline   Reply With Quote
Old 07-17-2015, 03:23 AM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
The combination of codes makes it "seem" like something is going bad with the fuel pressure. For example, the FPCM is thinking that you're getting 85 PSI and then cutting back on the fuel pump, so you're getting so little fuel to the engine, it's causing the passenger side of the engine (bank 2) to go lean. Or you having a failing fuel pump that just isn't supplying fuel correctly.
I've never dropped the fuel tank in mine. I cheated and cut the little access panel underneath the passenger seat. If you were to do it this way, you could probably do it yourself in a couple of hours. A pro doing it the right way should be >3 hours (guessing).
Jack Bilger
granatl is offline   Reply With Quote
p025a
