Old 07-15-2015, 01:16 PM   #1
1LEdabeast1LE
Nic@Night
Drives: 2015 Camaro 1SS/RS 1LE
Coolant Temps
What does yall's coolant temps run at on a daily street driven basis? track?
I have some concern that my 15' w/ 2000miles on it, is running too hot just driving around town. It is fluxing between 210-220deg f, same with the oil temp.
1LEdabeast1LE is offline   Reply With Quote
Old 07-15-2015, 01:48 PM   #2
Jc's1LE
Drives: 2015 SW 1LE BA NPP Recaros
Yup thats about right mine down here in Florida runs about 210
Jc's1LE is offline   Reply With Quote
Old 07-15-2015, 01:57 PM   #3
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Street: water 200, oil 215
Track: water 220, oil 280
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 07-15-2015, 09:34 PM   #4
PwrCrusr
PwrCrusr's Avatar
Drives: 2014 1LE
Mine sits on 192-194 on the open road. In heavy traffic it will climb until it hits 217 and the electric fans come on and cool it down to the 190's or so and they shut off - then the coolant cycles back to 217 and the fans kick on again.
2014 1SS 1LE SIM RS NPP
PwrCrusr is offline   Reply With Quote
Old 07-19-2015, 07:38 AM   #5
Bens1le
Bens1LE
Bens1le's Avatar
Drives: 2014 ss 1LE
PCM of North Carolina makes a fan wiring kit for our cars
Easy install and you can turn them on low and high speed way before 217
Bens1le is offline   Reply With Quote
Old 07-19-2015, 08:27 AM   #6
Peck1LE
Drives: Summit White 2ss 1LE/RS
Use a 160* thermostat for the summer & put stock thermostat back on for winter DD for the northern states
Peck1LE is offline   Reply With Quote
Old 07-20-2015, 03:48 AM   #7
X25
X25's Avatar
Drives: '16 C7 Z51
Or you can put on a 180 degree thermostat and never take it off : ) Not that the temps you are hitting are any problem, though. Your engine is designed to keep oil close to 212 degrees F.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
coolant, oil temp
