Old 07-17-2015, 02:49 PM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
8 rib conversion.
Will the innovators west 8 rib conversion hold 12 psi on my whipple without eating up belts to much. I get about 2500 miles on my 6 rib belts now. I won't ever go over 12 psi that's what I am running now with a 3.625 pulley.
ToddB is offline   Reply With Quote
Old 07-18-2015, 05:34 PM   #2
Supermaro54
Supermaro54's Avatar
Drives: 68,87,99 camaro,07TBSS
I was running a 3.5 pulley on 8 ribs. Can't recall it ever ripping or needing replacement. I say you will be fine with it. I switch to 10 rib 3" pulley after that.
2007 TBSS, forged 6.2, 2.9 whipple 9.9@135
(Now with CNC LSA, Numbers coming soon)
1999 Camaro SS, CNC LSA, 4L80, S60
1987 Camaro Iroc-Z, ZR1 blower, TR6060, S60
1968 Camaro SS, YSI 427 ERL in the works.
Supermaro54 is offline   Reply With Quote
Old 07-18-2015, 10:30 PM   #3
ToddB
Thanks. Then I should be fine with the 8 rib.
Old 07-19-2015, 11:11 AM   #4
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
I would think so, I'm at 13lb on the 6 rib and have change the belt one time in 3 year's. That with 3.75 pulley on S/C
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 07-19-2015, 12:08 PM   #5
nyny69
Drives: 2010 IOM SS
... Im also at 12 - 13 psi on a 6 rib. Never have shredded a belt yet. Sounds like something is not aligned correctly. I think most go to 8 rib due to slippage
nyny69 is offline   Reply With Quote
Old 07-19-2015, 02:48 PM   #6
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
2500 miles is ridiculously low. Something else is wrong, either belt tensioner is toast or an alignment issue. I've tried all kinds of crazy combinations of pulley sizes while working on our 10 rib kits that should be released fairly soon, and never had an issue even running 14 psi with 6 ribs, other than the slippage, belt lasted much longer than that.
2012LS3VERT is offline   Reply With Quote
Old 07-19-2015, 07:35 PM   #7
CobraR
Drives: 2010 2SS
Running a 8 rib on my tvs2300, 3.2" pulley, od cog on rear, 16-17psi, no indication of belt slip or major dusting.
CobraR is offline   Reply With Quote
