07-17-2015, 07:04 PM | #1 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
which side.....axles help!
Im installing my Gforce outlaw axles due to a broken drivers side axle. The previous axles were the gforce 1000hp and one finally gave out.
Anyway, i got the drivers side out, leaving in the stubs and thought it should just swap in. Gforce labeled the axles pass side and drivers side but the one labeled drivers side is too damn long. I have to remove the trailing arm outer bolt and that bolt wont come out due to it hitting the lower control arm. So my question, which side is actually the short side? ETA: nevermind. I removed the upper control arm bolt and the toe rod bolt and tilted the spindle down and slid it in that way.....duh!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
07-17-2015, 09:10 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
I didn't notice mine were different lengths at first...
After I noticed, I measured each axle and then measured the space between the inner and outer hubs (they were different lengths). The shorter axle went with the shortest distance and the longer axle in the longer distance. My axles weren't labeled. They appear to have identical amounts of lateral travel. |
07-17-2015, 09:30 PM | #3 | |
Not true. I had to remove the outer bolt from the upper control arm and toe rod and tilt the rotors outboard and slip in the axle from the top. I only did the broken(drivers side) then took it out for a spin. good as new. Will probably deal with the other side tomorrow, depending how the back and neck feel. Kinda had plans to blow threw a few hundred rounds out of the suppressed .300blk SBR though. Testing out some new subs.
07-17-2015, 11:28 PM | #4 |
The only thing I had to do was lower the trailing arm from the hub. They both slipped right in from the bottom. I did have to tighten bolt for each stub from the top. All the rest I could get to from the bottom.
I need to go shooting... I have thousands of rounds just begging to go boom. |
07-18-2015, 01:06 PM | #5 |
I tried that but the bolt from the trailing arm would not come out due to the lower control arm
07-18-2015, 04:37 PM | #6 | |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
07-21-2015, 02:07 PM | #7 | |
Drives: 05 GTO Join Date: Jul 2009
Thanks Chris |
07-21-2015, 06:04 PM | #8 | |
Thanks for the Outlaws! They are impressive. I plan to degrease the broken one and examine the shear closer. It was definitely a torsion failure, high cycle fatigue failure IMHO. I beat the hell out of these 1000hp axles the last 16000+ miles.
07-21-2015, 06:12 PM | #9 | |
Thanks Chris |
