Old 07-19-2015, 03:06 PM   #1
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
Vacuum leak - Reduced engine power
Hi,
I have a vacuum leak somewhere in the PCV area. When the hose is pulled off and closed no leaks anywhere, only when it's connected. All tested but there seems to be a leak somewhere in the engine itselve (not intake side,but crank side).
Any possibilities where it could be so I don't have to tear the engine apart to find the leak.
It goes in reduced engine power and idles very bad cold, long starting time etc. Also throwing code for low fuel pressure in rail 1 (No idea if related with vacuum leak).
Greetings,
Black '13 2LT RS
Thé only one 2013 LPG converted Camaro in the world
MRT V2, VTC
Mr Jos is offline   Reply With Quote
Old 07-24-2015, 02:30 PM   #2
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
Black '13 2LT RS
MRT V2, VTC
Old 07-24-2015, 03:29 PM   #3
Pathogen
Pathogen's Avatar
Drives: 2014 1LS Camaro
I have a vacuum leak tester. If you want to pay shipping, you can have it. PM me.
Nobody with a good car needs to be justified. -Flannery O'Connor
Pathogen is offline   Reply With Quote
Old 07-24-2015, 04:09 PM   #4
AITI
Drives: 2015 LFX Auto
You have the V6 LFX engine I assume? If so, the PCV foul side line is simple. It goes from the center top of the intake manifold to the barb on the rear of the passenger side valve cover. Check the valve cover side of it. If you have the LS3 it connects to the valley cover vent under the front of the intake manifold accessible from the passenger side front of the engine. If the L99, it connects to the rear of the drivers side valve cover. Did you add a breather to the valve cover by chance? That will act as a vacuum leak as your bypassing the MAF so the air entering is un-metered. Give us more info and we can try to help.
AITI is offline   Reply With Quote
Old 07-25-2015, 07:50 AM   #5
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
Hi,
I have the LFX yes.
I know where the PCV line is, and checked it for leaks and there are none in the line. The leak (it is audible) is somewhere in the engine block itselve, somewhere on the side or rear, but I can't find it. The sound is gone when the PCV line is pulled of and closed with a finger. I just don't know what parts are after the click-one connector, is it just a hole in the aluminium block itselve, or some replaceable part?
Black '13 2LT RS
MRT V2, VTC
Old 07-25-2015, 09:23 AM   #6
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
I presume you don't have any Chevy dealers thee in Belgium ? I would be taking it in to a dealer for this problem. They can do a fog test which may find the leak in 5 minutes. Or find a mechanic around your place that has a fog tester.
lawdog is offline   Reply With Quote
Old 07-25-2015, 10:03 AM   #7
MrChrisLS3
Drives: 2018 1SS M6
You could also get a mechanics stethescope (looks like a doctor's, except it has a rod at the end) pull the hose off the rod and listen around the area. If there is a leak, you'll definitely hear exactly where it's coming from.
MrChrisLS3 is offline   Reply With Quote
Old 07-26-2015, 05:02 AM   #8
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
I'll have to look monday. This year they stopped selling Chevy (and never sold V6 Camaro's in Europe) but I'll go for a fog test. Only problem is that all shops are on 3weeks holiday with reduced work being done.
Black '13 2LT RS
MRT V2, VTC
Old 07-27-2015, 03:17 PM   #9
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
Problem is solved. [Edit: Issue came back, see next post]
Low fuel pressure codes (on startup) are gone, no more bad idle/die at cold start.
Good old accelerating.
If someone gets the same, as hissing noice at passenger side around pcv, and goes into limp mode, this solved it for me:
Blowing air in the crankcase where normally the hose is attached. I don't know if the metal tube has a valve in it, but something happened and now no more vacuum leak.
I still have to put back the VTC (removed it few days ago) and the catchcan, I don't know if I'll put that one back, removed it out of the line 1week ago after I forgot to empty it (full can cause of everything perhaps?).
Black '13 2LT RS
MRT V2, VTC
Old 07-27-2015, 05:02 PM   #10
MrChrisLS3
Drives: 2018 1SS M6
Maybe caused a blockage in the PCV system and you blew it out with the air?
Old 07-28-2015, 05:14 AM   #11
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
After driving 200miles with no problem it came back while driving on the highway at a constant 75mph. Same vacuum hissing sound, gotta look at it when it stops raining.
Black '13 2LT RS
MRT V2, VTC
Old 07-28-2015, 09:58 AM   #12
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
Seems to be that it is pulling to much air from the dirty side PVC hose. With motor off and closing the clean side with my finger I can put it under pressure/vacuum by blowing on dirty side, so seems that there is no leak.
Could it be pulling to much air from the clean side somehow?
Black '13 2LT RS
MRT V2, VTC
Old 07-28-2015, 10:11 AM   #13
MrChrisLS3
Drives: 2018 1SS M6
Well, I'm not real up to speed on the LFX engine, however maybe you should refocus on that low fuel pressure code. I know that's a pretty big deal on the DI engines, and it may have nothing to do with the PCV system.
Old 07-28-2015, 02:03 PM   #14
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
The low fuel pressure code went away when the 'vacuum leak' was gone yesterday.
Seems that it pulls so much air that it's way to lean, and it tries to correct it but can't get there and trows low pressure code.
Is the PCV system on these engines without any valve at all? Just open clean side before throttle body, (I dont know what the big thing is in the line). And no valve either on dirty side? It is just pulling way to much air from the crankcase.
Black '13 2LT RS
MRT V2, VTC
