![]() ![]() ![]() ![]() Drives: 2013 VR vert ZL1 Join Date: Aug 2012
Hawks pads squeaking?
My 6 piston front calipers with hawk pads squeak when then they get warm. Is this normal?
Sent from my SM-N900P using Tapatalk |
When I lightly apply the brakes, it's squeaks, a a lot of pressure on the brakes pedal and no squeak.
![]() ![]() Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
When I first put in my HPS pads on my SS they were squealing like crazy after the first time I went to the track. Mostly on lighter stops as you described. Eventually it went away. Other time they just started chirping a bit, but I think it was dust or dirt, since after I powerwashed the wheels it went away.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
#4 | |
![]() ![]() Drives: 2010 SS RS Join Date: Apr 2009
I had Hawk Ceramics with SS Brembos for over 4 years (~22K miles) and they were quiet. Just did a quick bedding of HPS 5.0 pads in CTSV calipers. Been good for the last 4 day. |
#5 | ||
#6 | |
aerosportconcepts@gmail
![]() Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Thank you Kurt Robinson Aero Sport Concepts
#7 |
I've also just put the new Hawks 5.0 pads on my ZL1 and all is good on mine.
Pad squeel comes from a few different places; 1- brakes just need clean and service. Somerime you need to sand the surface face of the pad to clean them up 2- pads were not burnished in properly as oer the instructions 3- rotors were not cleaned properly before nrew pads were installed. 4- remember everything is a trade off. Nice quiet pads that dont make any noise are usually high in organic material but quickly over heat and have brake fade vs. higher metalic pads stand up to over heating but squeel a LOT. if you are really stuck feel free to PM me and I can walk you through some options. I work in the automotive industry and deal with these issues daily.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
#8 | |
#9 |
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Which pads you bought makes all the difference. HPS shouldn't make much if any noise, but anything HP+ and higher will be noisy.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#10 |
I just remember the box they came in was black and yellow. I'll take them off and put a lil sand paper to them and see if it helps.
I just hate when I pull up at a light and everyone looks at me like I need a brake job. But the brakes feel amazing. Sent from my SM-N900P using Tapatalk |
#11 |
![]() Drives: 2011 Camaro 2SS/RS Join Date: Sep 2010
I have Hawk HS pads that I use foe DD and the occasional track days in the summer. They don't squeal at the track; they do squeal at the lightest touch at stoplights when they are barely touching. A small price to pay for their excellence at the track and DD.
#12 |
Thanks for the confirmation. Yeah they work great for aggressive braking.
