General Motors Aficionado
Drives: 2023 GMC Canyon, 2023 Expedition Join Date: Aug 2008
GM Reveals 2016 Chevrolet Colorado/GMC Canyon Duramax Diesel
Chevrolet Introduces Colorado Duramax Diesel
All-new turbo-diesel expands lineup with unparalleled capability, efficiency General Motors July 28, 2015 ![]() DETROIT – The fastest-selling truck in the market now offers an available turbo-diesel engine. The 2016 Chevrolet Colorado Duramax diesel takes midsize truck capability and efficiency to unprecedented levels. With 369 lb-ft of torque (500 Nm) generated by its all-new 2.8L Duramax turbo-diesel, the Colorado’s maximum trailering capacity rises to 7,700 pounds (3,492 kg) on 2WD models, with estimated fuel economy projected to top the already segment-leading efficiency of the gas models. It is also the cleanest diesel truck engine ever produced by General Motors. “Simply put, there’s no other midsize truck that can do what Colorado can with its all-new Duramax diesel,” said Sandor Piszar, director of Chevrolet Truck Marketing. “Along with greater capability and efficiency, it expands the Colorado lineup to give customers more choices and the capability of exploring more possibilities on and off the road.” The new Colorado diesel goes on sales this fall, offered in LT and Z71 Crew Cab models, with 2WD or 4WD. It is priced $3,730 more than a comparably equipped 3.6L V-6 model. Features included with or exclusive to Colorado diesel models:
“A diesel engine was part of the Colorado’s portfolio plan from the very beginning, meaning the chassis, suspension and other elements of its architecture were engineered to support its capability,” said Scott Yackley, assistant chief engineer. “That means there are no compromises with the Colorado diesel. It offers exceptional capability delivered with a confident feeling of control.” Colorado’s award-winning combination of refinement, maneuverability and connectivity complements the diesel’s capability, with segment-exclusive features such as Chevy MyLink with phone integration technology – and compatibility with Apple CarPlay – OnStar 4G LTE with Wi-Fi hotspot, Lane Departure Warning and Forward Collision Alert. Colorado’s innovative solutions for hauling and accessing cargo include a standard CornerStep rear bumper, EZ Lift-and-Lower tailgate (standard on Z71 and available on LT), two-tier loading in the cargo bed, 13 standard moveable tie-down locations throughout the bed, an available, factory-installed spray-in bed liner and a line of available GearOn accessories. Inside the new 2.8L Duramax turbo-diesel Colorado’s new 2.8L Duramax turbo-diesel is part of GM’s global family of turbo-diesel four-cylinder engines designed to deliver value, capability and efficiency. It features a variable-geometry turbocharger for optimal power and efficiency across the rpm band and a balance shaft for greater smoothness. Power is SAE-certified at 181 horsepower (135 kW) at 3,400 rpm and 369 lb-ft of torque (500 Nm) at 2,000 rpm. A broad torque band makes it very powerful at low rpm, while the turbocharged performance provides a confident feeling of immediate and smooth horsepower on demand. “It is a no-compromise turbocharged engine that is also really fun to drive, with excellent responsiveness,” said Yackley. “It was also designed specifically for trucks and has undergone many of the same validation tests as the 6.6L Duramax, contributing to legendary Duramax durability and reliability.” Additional engine features:
The Duramax 2.8L is the cleanest diesel truck engine ever produced by General Motors, and meets some of the toughest U.S. emissions standards, thanks in part to a cooled exhaust gas recirculation (EGR) system. The cooled EGR contributes to lower emissions by diverting some of the engine-out exhaust gas and mixing it back into the fresh intake air stream, which is drawn into the cylinder head for combustion. That lowers combustion temperatures and rates, improving emissions performance by reducing the formation of NOx. Controlling noise and vibration with the CPVA To control vibration and noise inside Colorado, engineers integrated a device called the Centrifugal Pendulum Vibration Absorber (CPVA) in the torque converter used with the standard Hydra-Matic 6L50 six-speed automatic transmission. It marks the first application of a CPVA in a GM vehicle and the first time it has been used in the midsize truck segment. The CPVA is an absorbing damper with a set of secondary spring masses, that — when energized — cancels out the engine’s torsional vibrations so the driver and passengers can’t feel them. In its unique design, the spring masses vibrate in the opposite direction of the torsional vibrations of the engine, balancing out undesirable torsional vibrations. Smart exhaust brake details The Colorado’s integrated, driver-selectable exhaust brake system is based on the system introduced on the 2015 Silverado HD models and uses the compression power of the 2.8L Duramax engine to improve vehicle control and reduce brake pad wear. When the exhaust brake is engaged in cruise mode, exhaust cruise grade braking will help the cruise control system maintain the desired vehicle speed when travelling downhill, keeping the driver from having to apply the brakes and exit cruise control to maintain speed. When the exhaust brake is engaged in non-cruise mode, the transmission and the exhaust brake deliver the correct amount of braking to assist in vehicle control, regardless of vehicle load. It is a smart system that varies the amount of brakes needed for the vehicle, load and grade. The engagement of the system is smooth and quiet, while its performance enhances the driver’s feeling of control. Colorado at a glance Colorado, the 2015 Motor Trend Truck of the Year and Cars.com’s Best Pickup Truck of 2015, offers the most horsepower and best highway efficiency in the segment (27 mpg with 2.5L engine and automatic transmission), as well as the highest available trailering rating, for gas-powered models – 7,000 pounds (V-6 models when properly equipped) – and higher payload rating – 1,590 pounds (V-6 models when properly equipped). Chevrolet sold 41,575 Colorado trucks in the first six months of 2015, expanding the midsize truck market and driving new truck customers to Chevrolet – particularly in areas such as California and Texas, which have traditionally been hotspots for import brands. Photography ![]() ![]() ![]() ![]() ![]() ![]() GMC Canyon Expands Capability with New Duramax Diesel All-new turbo-diesel powertrain enables unmatched 7,700-lb. trailering capability General Motors July 28, 2015 ![]() DETROIT – GMC introduced the 2016 Canyon diesel today – featuring an all-new powertrain that expands the Canyon’s already class-leading capabilities, including trailering capacity of up to 7,700 pounds (3,492 kg). The new 2.8L Duramax diesel, SAE-certified at 181 horsepower (135 kW) and 369 lb-ft of torque (500 Nm), is estimated to deliver greater highway fuel economy than the Canyon’s segment-topping gas engines, and is the cleanest diesel truck engine ever from General Motors. It goes on sale this fall. Several new technologies and supporting features complement the Duramax diesel’s capability while helping ensure GMC’s trademark refinement:
“The new Duramax diesel takes the GMC Canyon's award-winning capabilities to a new level in its segment,” said Duncan Aldred, vice president of GMC Sales and Marketing. The new Duramax diesel is offered on SLE and SLT Crew Cab models, with 2WD or 4WD. It is priced $3,730 more than a comparably equipped Canyon V-6 model. All diesel-equipped models feature the Trailering package, which includes a hitch receiver and seven-pin connector, as well as the segment-exclusive automatic locking rear differential, a 3.42 rear axle ratio and four-wheel disc brakes with Duralife™ brake rotors. Capacities include:
A fully boxed frame provides the strength to enable the capabilities of the new Duramax diesel while supporting a ride designed to be smooth and quiet. Like the full-size Sierra’s frame, Canyon features three sections – or bays – with specific strength and support characteristics, including a front bay made of hydroformed side rails and an integrated four-point front axle mounting system designed to reduce vibration. “A diesel engine was part of the Canyon’s portfolio plan from the beginning, meaning the chassis, suspension and other elements of its architecture were engineered to support it,” said Scott Yackley, assistant chief engineer. “That means there are no compromises with the Canyon diesel. It offers exceptional capability delivered with a confident feeling of control.” When it comes to putting that capability to use, Canyon offers helpful cargo features such as the standard CornerStep rear bumper, two-tier cargo bed loading, 13 standard movable tie-downs in the cargo bed, an available factory spray-in bed liner and the EZ Lift-and-Lower tailgate. In addition, the 2016 Canyon offers technologies and connectivity features such as GMC IntelliLink with new phone integration technology – and Apple CarPlay capability – OnStar 4G LTE with Wi-Fi hotspot, Lane Departure Warning and Forward Collision Alert. All-new 2.8L Duramax turbo-diesel details Canyon’s new 2.8L Duramax turbo-diesel is part of General Motors’ global family of turbo-diesel four-cylinder engines designed to deliver capability and efficiency. It features a variable-geometry turbocharger for optimal power and efficiency across the rpm band and a balance shaft for greater smoothness. Power is SAE-certified at 181 horsepower (135 kW) at 3,400 rpm and 369 lb-ft of torque (500 Nm) at 2,000 rpm. A broad torque band makes it very powerful at low rpm while the turbocharged performance provides a confident feeling of immediate and smooth horsepower on demand. “The new 2.8L Duramax was designed specifically for trucks and has undergone many of the same validation tests as the 6.6L Duramax offered in the GMC Sierra HD models, advancing the Duramax brand’s legacy of durability and reliability,” said Yackley. Additional engine features:
The Duramax 2.8L is the cleanest diesel truck engine ever produced by GM and meets some of the toughest U.S. emissions standards, thanks in part to a cooled exhaust gas recirculation (EGR) system. The cooled EGR contributes to lower emissions by diverting some of the engine-out exhaust gas and mixing it back into the fresh intake air stream, which is drawn into the cylinder head for combustion. That lowers combustion temperatures and rates, improving emissions performance by reducing the formation of NOx. Smart exhaust brake details The Canyon’s integrated, driver-selectable exhaust brake system is based on the system introduced on the 2015 Sierra HD models and uses the compression power of the 2.8L Duramax engine to improve vehicle control and reduce brake pad wear. When the exhaust brake is engaged in cruise mode, exhaust cruise grade braking helps the cruise control system maintain the desired downhill vehicle speed, keeping the driver from having to apply the brakes and exit cruise control to maintain speed. When the exhaust brake is engaged in non-cruise mode, the transmission and the exhaust brake deliver the correct amount of braking to assist in vehicle control, regardless of vehicle load. It is a smart system that varies the amount of braking needed for the vehicle, load and grade. The engagement of the system is smooth and quiet, while its performance enhances the driver’s feeling of control. CPVA contributes to refinement The Centrifugal Pendulum Vibration Absorber (CPVA) in the torque converter is designed to control vibration and noise. It is an absorbing damper with a set of secondary spring masses, that — when energized — cancels out the engine’s torsional vibrations so the driver and passengers can’t feel them. In its unique design, the spring masses vibrate in the opposite direction of the torsional vibrations of the engine, balancing out undesirable torsional vibrations. Its use in the Canyon marks the first application of a CPVA in GM vehicles and its first use in the midsize truck segment. Critical acclaim In 2015, Canyon won Cars.com’s Midsize Pickup Challenge for its segment-leading capabilities and efficiency, including the latest in safety features, cargo-hauling and trailering versatility. Cars.com also complimented the Canyon SLT, the segment’s only premium vehicle, for its performance with a full load, as well as its design and use of high-end materials. Autoweek honored Canyon as the “Best of the Best Truck for 2015,” and Wards Auto World recognized Canyon as one of Ward’s 10 Best Interiors for 2015, based on criteria such as design harmony, ergonomics, materials, driver information, safety and comfort.
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) Last edited by FenwickHockey65; 07-28-2015 at 01:07 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Nice. That should sell very well.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
When can I haz!!!!!
i want one!
Moderator.ca
Surprised the tow rating isn't even higher. Though I'm sure that the diesel will be a lot happier towing a heavy load than the V6 will, even if its only rated for a couple hundred pounds.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Diesel has a negative stigma here in the States.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#7 | |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
That's not bad.
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
#8 |
For no good reason these days.
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
#10 |
Recalled user
I agree. I think folks were expecting the Colorado to be cheaper in general.
Hell, can you even buy a new car for under $40K these days
#11 |
![]() Drives: 2012 Ford Focus Join Date: Jan 2014
If its unable to beat the ram in mpg's, it'll be a total fail IMO.
#12 |
![]() Drives: 2010 Camaro LT2/RS Join Date: Apr 2011
That's $5k for the diesel over the base 4 cylinder gas, seems kinda high maybe, idk
#13 |
220/221 whatever it takes
Drives: See sig.... Join Date: Jun 2010
I agree, but this is one of the main reasons in my area that's doing it....
![]() ![]() Trucks like these are all over the roads here in central Indiana and the rednecks driving them are not helping persuade folks such as my wife. She absolutely hates diesels now.....and 15 years ago she was totally indifferent.
Brent
2022 BMW X5 M50i 2022 Ram TRX 2021 GT500 CFHP 2016 Challenger Hellcat A8 1058whp/898wtq 1970 Chevelle SS396 4spd |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
I drove it...
![]() The Torque ... ..is Amazing! ![]() ![]() Becky |
