Old 07-28-2015, 11:32 PM   #1
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
bad gas or.....
recently every time i get done filling up gas and go to start my car it hesitates for a moment and then starts up. and after filling up one night i got a cel the next morning. put some fuel injector cleaner in (usually solves this problem) couple of days after and still getting cel, power is fine but im not sure if i should just run the gas out or not.
_Onyx_Wolf_ is offline   Reply With Quote
Old 07-29-2015, 07:29 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
It's not bad gas. I would go get the CEL referenced and see what the car is telling you.
TheHorse13 is offline   Reply With Quote
Old 07-30-2015, 08:08 AM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Agreed. You have a problem that could eventually leave you stranded one day. Get to a dealer.
Rock-It Man is offline   Reply With Quote
Old 07-30-2015, 10:29 AM   #4
AITI
Drives: 2015 LFX Auto
Your injectors wont live long if your using fuel injector cleaner that often. Just because a little can be used rarely does not make alot better. The solvents will attack the internals of the injector and can cause premature failure.
AITI is offline   Reply With Quote
Old 07-31-2015, 01:42 PM   #5
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Do you top it off after the gas pump automatically shuts off? I've heard problems about the vent valve, purge or canister for this issue, get the codes checked
TommyTheCat is offline   Reply With Quote
Old 08-02-2015, 02:19 PM   #6
TooCool5
TooCool5's Avatar
Could be water in the gas. Gets stirred up when you fill it.
Try a bottle of dry gas in the tank.
