Old 07-29-2015, 05:50 PM   #1
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
ZL1 Rear vs. Dana 60
I narrowed my choice down to these two and would like some input.
I have a 2010 SS M6 with a Vortech V3 Est RWHP 520
Street Slayer Twin Carbon
Complete BMR suspension
MGW shifter
DSS 1000HP axles
Future mods might be smaller blower pulley and a cam
Est Future RWHP 630
I can get a new GM ZL1 kit with axles and driveshaft for about 4000.
Is there any reason to go with the Dana 60 over the ZL1 since I plan on going with the 3.73 ratio?
What would be the cost of a Dana 60 and can I reuse my DSS axles?
redirish is offline   Reply With Quote
Old 07-29-2015, 08:13 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
PM sent
Driveshaftshop is offline   Reply With Quote
Old 07-29-2015, 10:14 PM   #3
smokum
smokum's Avatar
Drives: 2010 2ssrs
You can pick up a whole zl1 complete rear subframe for around 3k. Zl1 for sale section has a 3.73 setup with axles diff brakes for 2000. Check it out. Only need a driveshaft which the driveshaft shop has a nice one.
smokum is offline   Reply With Quote
Old 07-30-2015, 06:24 AM   #4
MA2010SS
Drives: 2010 Camaro SS
Noisy strong setup or quiet strong setup. I changed my noisy strong setup to a quiet strong setup. 3.73 gears was good enough for me. Just my $.02
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 07-30-2015, 12:46 PM   #5
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
Can the zl1 handle 1000rwhp full weight Camaro in the 8.90-9.00 range?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 07-30-2015, 02:38 PM   #6
MA2010SS
these zl1 guys are in the 125mph - 140mph range. Most likely they are running the stock 9.9" rear
https://docs.google.com/spreadsheet/...DZzMm15TzVtX1E
Old 07-31-2015, 12:27 PM   #7
RedRyder
RedRyder's Avatar
Drives: 2010 VR 2SS/RS M6 Camaro
FYI - Jegs has the ZL1 kit right now for only $3500
RedRyder is offline   Reply With Quote
Old 08-02-2015, 08:14 AM   #8
Craig B
Craig B's Avatar
Drives: 2013 1LE
That looks like a good deal!!
Craig B is offline   Reply With Quote
Old 08-02-2015, 10:17 AM   #9
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
Yes, especially with free shipping and no tax.
I paid about $4K for my kit. I also found out later the kit was overpriced by Chevy compared to piecing out the parts yourself. This could still be true.
If I had it to do over again I think I would go ZL1 diff for quiet strength, and after market axles and drive shaft to save a few pounds.
Old 08-02-2015, 07:44 PM   #10
redirish
redirish's Avatar
I have a new ZL1 rear and after market axles on order. Not sure about the driveshaft thinking of just going with the ZL1 stock shaft. I hear some of the after marker shafts are noisy
Old 08-03-2015, 10:39 AM   #11
Driveshaftshop
We have started using a sound deaden-er in the tube of all our new shafts. Just an FYI for all Camaro Guys. there is no sound deadening in the back of these cars, pull up the back seat and you will see that its bare metal so any noise at all even "normal" noise will be echoed into the cabin.
This info is good (click here)
Old 08-03-2015, 11:51 AM   #12
RankSS
I have gathered all the parts for my rear diff upgrade.
Went with slightly used ZL1 diff and axles, a DSS aluminum driveshaft and H-E's offset bushings.
Now to just drop the subframe and make it all fit. Probably would not need to drop the subframe but I have a fuel leak I need to address as well.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
