Old 07-31-2015, 08:21 PM   #1
Sprankster
Drives: 2012 SS/RS
BBK Throttle Body issues
I bought the 95mm version about a year ago and installed it. After I installed it I took it for a test drive and my CEL came on and I got reduced engine power. Had about zero acceleration and the car was shaking alot. Put the stock one back on which stopped the shaking and with about 20 miles of driving the CEL turned off. Then I had to leave the country for a year and forgot about it.
Got back and figured I would give it another go. Same exact thing happened. Does anyone have any idea what is happening or did I get a bad throttle body and am screwed since I bought it over a year ago.
Edit: This is the same issue mine has. If I had to do it again I would just do a VMAX ported one instead of BBK.
Sprankster is offline   Reply With Quote
Old 07-31-2015, 11:12 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
you've got the BBK curse : requires replacing the offending part with one that is not a PITA. GEE I never heard yet of anyone liking it when they got a BBK..... only troubles...do a search with BBK in it... good luck it seems they almost always have calibration issues and some tried addressing it in tunes and some just gave up even after doing everything they could.
Old 08-01-2015, 08:38 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Unfortunately, this is correct. We had one of our local guys go thru this saga even after we told him he did not want a BBK throttle body. After months of headaches he ended up putting a VMAX ported throttle body on like we recommended from the get go.
Old 08-01-2015, 10:15 AM   #4
Sprankster
Drives: 2012 SS/RS
Figured out that the issue is that the blade scrapes really hard against the bottom causing it to stick. Now I get to hear them say there is nothing I can do because I was deployed for a year.
Old 08-01-2015, 11:40 AM   #5
Bo White
Bo White's Avatar
You didnt check it before you put it on?
Old 08-01-2015, 01:14 PM   #6
Sprankster
Drives: 2012 SS/RS
Didn't know that this was a know issue or that BBK had bad quality control. I guess I shouldn't put my faith in companies to send me working parts out of the box. But thanks for the comment.
Old 08-01-2015, 02:19 PM   #7
AITI
Drives: 2015 LFX Auto
Common. Have never had luck with any BBK TB's on any applications.
AITI is offline   Reply With Quote
Old 08-01-2015, 05:11 PM   #8
Sprankster
Drives: 2012 SS/RS
Thank you. Hindsight is 20/20.
Old 08-01-2015, 06:03 PM   #9
1989GTA
Drives: 1989 GTA Trans Am
Cannot the blade be adjusted by loosening the screws so that it does not bind or rub. I have seen where people have done this to get the TB to work correctly. It would be worth a shot.
1989GTA is offline   Reply With Quote
Old 08-01-2015, 06:04 PM   #10
Sprankster
Drives: 2012 SS/RS
All the screws do for me is strip and not the fun kind.
Old 08-01-2015, 06:33 PM   #11
Bo White
Bo White's Avatar
Once you swap parts over from one TB to another I would think people would cycle the blade by hand to make sure everything was good.
Old 08-01-2015, 06:58 PM   #12
Sprankster
Drives: 2012 SS/RS
Thank you for the same comment.
Old 08-01-2015, 08:00 PM   #13
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
It's an expensive paper weight.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 08-01-2015, 08:07 PM   #14
Sprankster
Drives: 2012 SS/RS
Might be able to get a couple of bucks for it at a scrap yard.
