Old 08-02-2015, 12:30 PM   #1
scites
Drives: 2010 camaro SS/RS
BAP question
Have a few questions if you guys can help. So last year I installed HFC and a vortech V3si kit on the camaro A6, car ran 12.3@113 on stock 21in wheels/tires. This past friday I installed the 3.47 pulley to raise boost to about 8.5ish, tow links, poly bushings, LCA and drag radials18in.car was maxing out the inj duty over 5800rpm so at 1am I installed a ECS bap, inj duty stays under 80% now. Problem is I went to the track and my AFR is 10.1 at the leanest at WOT pig rich and the car is sluggish. And I ended up running a 13s@105. Didnt think id have to retune after the BAP is this normal? Really made the weekend ďìssapointing. ?
scites is offline   Reply With Quote
Old 08-04-2015, 12:53 PM   #2
scites
BUMP..anyone?
Old 08-20-2015, 01:14 PM   #3
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
I'm not sure if this helps, as our setups are a bit different, but my BAP doesn't even kick in until I'm at about 125MPH. Then it makes the mix rich for just a small amount of time.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 08-21-2015, 12:21 AM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Yes perfectly normal. You have increased your FP, so you will need to compensate for that in the tune.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 08-21-2015, 12:25 AM   #5
1KillerSS
1KillerSS's Avatar
The ECS BAP works on a Hobbs switch, so you may want to verify that your indeed increasing pressure under boost, and that the BAP is not active all the time.
Build thread
