Old 08-03-2015, 05:44 PM   #1
mitsu7807
Drives: 2010 ss rs
boston acoustic worth replacing ?
I am very un impressed with my 2010 ss with boston acoustic stereo .....would it be worth upgrading the door 6.5 speakers and or the 6x9 ? and still keep stock boston amp head unit and wiring .....just upgrade speakers ? would that even work and if so would it sound better .......I don't really like subwoofers
mitsu7807 is offline   Reply With Quote
Old 08-03-2015, 06:06 PM   #2
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Best thing I found was unplugging the center speaker in the top of the dash and I threw an amp and a 10" sub in a box in the trunk (had both from a previous setup). Bought the wiring kit from a vendor on here and it plugged into the factory amp and works great.
I know that doesn't go along with what you're looking to do but it's my experience.
Not sure what kind of music you listen to but IMO my setup can make any kind sound good. I listen to rock and old country.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 08-03-2015, 07:41 PM   #3
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
First thing to replace is the amp. The stock system is underpowered.
Second, add a sub. Then you can reduce the bass to the main speakers which will further diminish distortion.
Then, consider replacing the speakers. And even then, you likely only need to replace the door speakers. The rear are just fill.
JimE is offline   Reply With Quote
Old 08-04-2015, 08:49 AM   #4
Imdyinhere
Keeper of the Gold Acorn
Imdyinhere's Avatar
Drives: 2011 2SS/RS
This is a spot on recommendation. The BA amp is extremely under powered and when you turn up the stock head unit the distortion goes way up which is bad for everyone. There are a lot of options available that will fit into the stock location and the FARK harness from Sub Thump makes swapping it out a breeze. That way you can keep the head unit volume lower (thereby lowering the THD) and still listen to your tunes at ear bleeding levels. Add a quality sub (powered by the new amp if you go 5ch or separate mono amp) and youre in business. The difference will SHOCK you.
2011 RJT 2SS/RS - Kooks 1-7/8 Long Tubes, High Flow Cats, Corsa Cat Back Exhaust, MTI Short Throw Shifter, Vmax Ported Throttle Body, Fasster Billet Fuel Rails & Custom Braided Vapor and Fuel Lines, CAI Cold Air Intake, RX Catch Can, Nitto Invos, Hawk HPS, BMR Trailing Arms, 2x Zapco ST4x-SQ amps, ST850x-II Sub amp, Morel Tempo 6 componenets, Morel Maximo 6x9, Morel 124 Primo Sub, Zapco DSP8Z Processor... More to Come.
Imdyinhere is offline   Reply With Quote
Old 08-04-2015, 09:47 AM   #5
mitsu7807
Drives: 2010 ss rs
So I can use one amp to power the speakers and a sub? ...I plug that harness in and then what disconnect the stock amp or will it just get taken over by the new one .....and can one amp do both ?
Old 08-04-2015, 11:35 AM   #6
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
Ditto. If you cannot do an entire system upgrade at once, this is the correct order you do them in.
- The one amp method is preferred for "easiest plug and play"
- Yes, you will perform an 'amp delete mod'
I would start with an Alpine PDX-v9, is the current "stock amp replacement favorite in quality" http://www.camaro5.com/forums/showthread.php?t=416081. I do not suggest the MRV-500 because, while it's 25% cheaper, you lose HALF the power and quality.
You'll need the full FARK kit (~130) and the "stock amp rack" kit thingy.
You'll also need a basic power kit for amplifiers, Knukoncepts is the preferred quality wiring source; KnuKoncepts 4 gauge kit
Snoman is offline   Reply With Quote
Old 08-04-2015, 02:39 PM   #7
mitsu7807
Drives: 2010 ss rs
You have been a great help ...how do u do amp delete ......and Iis the basic mission to get a 5 channel amp 4 channels for car and one sub ? ...thanks again
Old 08-04-2015, 08:34 PM   #8
JimE
JimE's Avatar
This was all covered above, I'm not sure what you don't understand.
All you are doing is replacing the factory amp with an aftermarket amp.
Get a 4ch amp as a standard amp replacement.
If you are going to install a sub, you can use a 5ch amp or a 4ch amp (speakers) and a 1ch amp (sub).
Old 08-05-2015, 09:57 PM   #9
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
I have upgraded the stereo in two fifth gen camaros, a 2010 1LT non boston system and a 2011 2SS BA system. had to run wires in the non BA and replaced the door speakers, added a 5 ch amp and 10 inch Sub. loved the way it sounded even though the total watts was in the 750 or so range. in the SS I replaced the door speakers with some nice Polk Components, upgraded with a FARK to an alpine PDR F50 mounted in the stock location, Sub~thump side fire box with built in shelf, 10 inch Alpine Sub and an alpine mono amp. it sounds great and probably louder than I need. total watts of the system is about 1000, center speaker disconnected(don't miss it). play it as loud as I want and no distortion! crisp and clear at any volume!!
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 08-08-2015, 09:52 PM   #10
flyer08
Drives: 2010 2SS/RS
It is def worth it. Replaced everything with hertz speakers and jl amp and sub and its night/day difference. Just amp alone before new speakers was a big upgrade
Hertz HSK fronts
Hertz ECX 690 rear
Jl 12w3 sub
Jl 900/5 amp
flyer08 is offline   Reply With Quote
Old 08-16-2015, 12:56 PM   #11
jwhutton52
jwhutton52's Avatar
Drives: 2014 Camaro 2SS / RS Coupe
Hertz HSK fronts
Hertz ECX 690 rear
Jl 12w3 sub
Jl 900/5 amp
Did you have an EMI problems with the HD amp?. FM radio interference? I've heard those amps generate a lot of RF noise.
jwhutton52 is offline   Reply With Quote
Old 08-16-2015, 03:43 PM   #12
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
I just finished an upgrade to the BA system in my '14 2LT. I used a FARK amp replacement kit along with a sub thump 10" driver's side box and thier amp rack...worked great.
I used DLS Audio 6.5" Ultimate Series component set for the front stage, and left the factory 6x9's for a tiny bit of rear fill. I also used DLS Audio amps, all are audiophile grade class AB, including the amp used to drive the DLS Audio SQ cast basket 10" subwoofer, so no class D amps and no system noise at all, the system has about 700 watts RMS.
DLS Audio is a European company that has been making audiophile quality and competition speaker product for over 30 years, very big in the European competition circuit and have done some IASCA here in the US.
I am also using an Audio Control DQDX for digital time alignment, crossover, EQ and line driver, really helps the front sound stage and also moves the woofer output into the interior of the car, makes it appear to come from the front kick panels.
All in all, this is by far the best sounding system I have ever had, very close to Focal in sound quality.
jeffa is offline   Reply With Quote
Old 08-27-2015, 10:32 AM   #13
GSE_Anthony
GSE_Anthony's Avatar
Drives: 2012 Camaro SS 45th Ann Edition
Great thread, I haven't been thrilled with the BA system since day 1 and hope to make some changes so this is good info for me!
GSE_Anthony is offline   Reply With Quote
Old 09-16-2015, 07:05 PM   #14
Jasper
Jasper's Avatar
Drives: 2011 Summit White Camaro SS (LS3)
I've always like the BA setup in my car. It will never sound as good as aftermarket but anything louder just covers up the sound of the LS3. Do the coupes come with the subwoofer? I know my Vert has one and think it's amazing how good it sounds even with the top down. Would have thought I would lose a lot to the free air.
J
Jasper is offline   Reply With Quote
