Old 08-03-2015, 10:02 PM   #1
fluxzl1
Drives: 2015 ZL1
service stabilalink??
well.. drivin along today in my 2015 ZL1 and the service stabilalink came on
the car quit and will not restart, so up on the tow truck back to the dealer..
anybody have this happen???
fluxzl1 is offline   Reply With Quote
Old 08-06-2015, 11:38 AM   #2
Emvici
Drives: 2014 ZL1 White Convertible
augh, that is crummy. did you do any aggressive driving shortly before the warning came on?. I hope it all goes well. tow trucks and zl1's don't match up well.
Emvici is offline   Reply With Quote
Old 08-06-2015, 12:04 PM   #3
fluxzl1
Drives: 2015 ZL1
thanx... thay cant get the problem to duplacate so it will be at the dealer till it dose...
no aggressive driving it just died...
Old 08-06-2015, 02:54 PM   #4
gmjj13
gmjj13's Avatar
Drives: 2015 ZL1
Had a similar problem. ECM went bad. Dealer replaced ECM, and good to go now.
gmjj13 is offline   Reply With Quote
Old 08-08-2015, 10:50 AM   #5
fluxzl1
Drives: 2015 ZL1
this sucks.. dealer cant get the car to act up... and if it dosnt act up
thay cant fix it ,so thay say... not sure what im going to do now...
Old 08-08-2015, 11:31 AM   #6
69ZLover
69ZLover's Avatar
Drives: 2015 ZL1
This happened to me last week from a cold start. Pulled the #5 EMC fuse and it reset it self then restarted and all was fine. Had the service engine light on for that drive but when I restarted it the next time it too was cleared. Sounds crazy odd but it fixed mine... Edit
69ZLover is offline   Reply With Quote
Old 08-08-2015, 09:27 PM   #7
fluxzl1
Drives: 2015 ZL1
Originally Posted by 69ZLover View Post
This happened to me last week from a cold start. Pulled the stabi fuse and it reset it self then restarted and all was fine. Had the service engine light on for that drive but when I restarted it the next time it too was cleared. Sounds crazy odd but it fixed mine...
this happened to mine to like 4 times, same exact thing but i never pulled the fuse it just started after a few min. then the last time it killed on the road...
Old 08-09-2015, 12:53 AM   #8
Sabin ZL1
Sabin ZL1's Avatar
Drives: 2012 Camaro ZL1
Yes it is the ECM. Same thing happened to me about 3 times until they changed the ECM. No problems since. I believe there is some Service Bulletin or something like that out. Their ECM is garbage. If I waited until the next day it would start also.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=100096&dateline=14270  90893
Sabin ZL1 is offline   Reply With Quote
