Old 08-04-2015, 05:07 PM   #1
CallmeMacc
Drives: 2010 Black LS
Chevy switchblade transponder chip
Does anybody know if the chip is actually in the physical key or is it just on the board. I'm asking because I just switched my fob (unlock button fell out) and need to get it cut but not sure if it needs to be programmed because I just moved the board over to a new casing
CallmeMacc is offline   Reply With Quote
Old 08-04-2015, 05:19 PM   #2
CFD
Drives: 2SS/RS L99 BLACK
it's on the board in the fob.
CFD is offline   Reply With Quote
Old 08-04-2015, 05:21 PM   #3
CallmeMacc
so just getting the key cut should be all I need?
Old 08-04-2015, 05:25 PM   #4
CFD
Yes, if you swapped over the board you should be all set.
Old 08-04-2015, 05:28 PM   #5
CallmeMacc
Thanks
