Old 08-04-2015, 10:13 PM   #1
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
My 1LE is getting a better brake upgrade
Due to an unforeseen circumstance I needed new front calipers. I over torqued my bleeders in my 6 piston V calipers last fall at the track (knowingly) and then the car wasn't tracked again until this past Saturday. The torque and heat from the race pads seized the bleeders into place. Friday night I sheared off both LH and RH front caliper bleeders......so I bleed the inside of both and ran at the track as planned.
I had planned on upgrading the Vs with the 2015+ Corvette Z06 non-CCB vented pistons..... But these now seem appropriate. I will fix the Vs later.
Matt.
Old 08-04-2015, 10:14 PM   #2
Dropspeed
Dropspeed's Avatar
I can only post one pic at a time from my phone. Dollar was size ref for a friend.
Old 08-04-2015, 10:15 PM   #3
Dropspeed
Dropspeed's Avatar
Mmmmm vented pistons. These are good for about a 86f reduction in temp.
Old 08-04-2015, 10:55 PM   #4
2010Camaro1ss
2010Camaro1ss's Avatar
Drives: 2014 Camaro 2ss 1LE
Are these bolt on?
2017 Corvette Z06
1993 Corvette
1980 Corvette
2010Camaro1ss is offline   Reply With Quote
Old 08-05-2015, 12:09 AM   #5
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I believe they are direct bolt on; essentially a CTS-V caliper with better pistons. I'm curious if they offer rebuild kits with pistons and seals.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-05-2015, 12:31 AM   #6
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Okay now I'm curious!
Sapper12b is offline   Reply With Quote
Old 08-05-2015, 12:34 AM   #7
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
Is there less transference of heat to the fluid with those pistons?
Stock Boy is offline   Reply With Quote
Old 08-05-2015, 12:50 AM   #8
cabbe
Drives: 2014 2ss 1le
Are they much more expensive than the V's
cabbe is offline   Reply With Quote
Old 08-05-2015, 04:55 AM   #9
X25
X25's Avatar
Drives: '16 C7 Z51
All Corvette calipers go for $300-400, so it should not cost too much. That said, I suppose it would only be worth an upgrade if you already destroyed your own CTS-V calipers, and bored of buying the same cheap calipers all the time :P
Why not just a good set of BBKs? Yes, they are more expensive, but they also come with improvements. For instance, taking a quick look at StopTech's aero rotor v.s. the ZL1's 2-piece quickly reveals why one would promote a few times more air flow than the other.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 08-05-2015, 06:38 AM   #10
Dropspeed
Dropspeed's Avatar
Yes they are a direct bolt on with the Zl1 rotor.
They are not on Amazon yet, but they sell for $400//$425.
Yes the pistons helps with the heat transfer.
Yes the piston kit is available to upgrade V and Zl1 brakes. It is $119 per caliper (6 pistons) or $164ish with new seals included.
Why not a better BBK.....Time!!! Ran the car Saturday and I need (want) to be back 100% because I will be back at the track this coming Sat/Sun. Decided on these instead of another V set and upgraded pistons for roughly the same cost.
Matt
Old 08-05-2015, 12:25 PM   #11
2010Camaro1ss
Matt
Do you have part numbers?
2017 Corvette Z06
1993 Corvette
1980 Corvette
Old 08-05-2015, 12:55 PM   #12
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Hmmm. I like that they are already red as well. I'll definitely have to keep this in mind for the future should I ever have to replace my CTS-V calipers I have on the car now.
BTW...what race pads are you using. I had thought up to this point you had always been running the stock Ferrodo 1000 pads? Were you having fade issues with the stock pads that you switched?
Thanks for the info Matt!!
Nick S is offline   Reply With Quote
Old 08-05-2015, 02:57 PM   #13
Sapper12b
HTCC Member
Sapper12b's Avatar
What year corvette are the calipers off of ?
Old 08-05-2015, 02:58 PM   #14
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Got the numbers from www.gmpartsclub.com I'm sure there is cheaper but its a start on P/Ns and this for a 2015 Stingray
7 22847783 CALIPER, LEFT W/O Z06, W/O Z51 PKG, GRAY $769.56 $515.41
7 22847785 CALIPER, LEFT W/O Z06, W/O Z51 PKG, RED $769.56 $515.41
7 22847795 CALIPER, LEFT W/O Z06, W/Z51 PKG, RED $714.08 $419.52
7 22847796 CALIPER, RIGHT W/O Z06, W/Z51 PKG, BLACK $714.08 $419.52
7 22847788 CALIPER, RIGHT W/O Z06, W/O Z51 PKG, GRAY $769.56 $515.41
7 22847784 CALIPER, LEFT W/O Z06, W/O Z51 PKG, YELLOW $769.56 $515.41
7 22847789 CALIPER, RIGHT W/O Z06, W/O Z51 PKG, YELLOW $769.56 $515.41
7 22847791 CALIPER, LEFT W/O Z06, W/Z51 PKG, BLACK $714.08 $419.52
7 22847794 CALIPER, LEFT W/O Z06, W/Z51 PKG, YELLOW $805.88 $473.45
7 22847799 CALIPER, RIGHT W/O Z06, W/Z51 PKG, YELLOW $805.88 $473.45
7 22847800 CALIPER, RIGHT W/O Z06, W/Z51 PKG, RED $714.08 $419.52
7 22847790 CALIPER, RIGHT W/O Z06, W/O Z51 PKG, RED $769.56 $515.41
