Old 08-05-2015, 01:45 PM   #1
scites
Drives: 2010 camaro SS/RS
how do you upload a HP tuner file?
can someone please explain how to upload a HPT file? iv tried with no success ..
scites is offline   Reply With Quote
Old 08-05-2015, 02:30 PM   #2
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Using the cable and box that comes with HP Tuners? Wont work without it. Also, it needs to be licensed to your vin, has that been done?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 08-05-2015, 02:34 PM   #3
blake-b
blake-b's Avatar
Drives: 2009 ZR1
If you are talking about posting a tune file in the forum:
The .cfg extension isn't enabled on this forum. It's up to the admins to allow it. You will have to host it somewhere such as google drive and then link that in your post.
If you are talking about uploading it to your car, what IneedAZ said is correct.
Old 08-05-2015, 05:19 PM   #4
scites
Thanks guys, I was talking about on the forum.
Old 08-05-2015, 10:46 PM   #5
black.
Drives: IBM 2SS
Try hptuners forum, there's a whole lot of help over there.
black. is offline   Reply With Quote
Old 08-05-2015, 11:55 PM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Correct me if i'm wrong, but cant you just compress the file and then post it as a Zip?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
