![]() ![]() Drives: 2014 2SS/RS Join Date: Jun 2013
How to adjust handbrake
Title says it. I have to pull it sky high for my car to even stay. Do I have to remove the console to adjust the line? Also, do I have to remove the console to remove the spring in the handbrake? Or does the plastic boot pull off?
![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I adjusted mine when I had the rear rotors off. There is a ratcheting wheel back there that tightens the parking brake. Mine didn't hold the car at all. Now it holds pretty well.
BUMBL Z
it's not a fun process, involves taking the rear wheels, calipers, and rotors off, and adjusting the parking brake drum until it holds. Might i recommend raising the lever a few clicks (2 or 3) before making any adjustments
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
Aw seriously? All of that? In my old eclipse, all i had to do was take apart the console and tighten the line by adjusting a nut...
BUMBL Z
yeah, i wish it were that easy, however, no such luck
#6 |
I want to adjust it tighter than stock for drifting purposes.. plus the spring removal. I found the line under my car, but its all blocked off by heat shields. Looking at the manual later.
#7 |
BUMBL Z
drifting purposes? oh boy lol, this i wanna see
#8 |
its the only way to properly use the pzeros
#9 |
Mine wasn't worn, but still needed adjusting. The nature of applying the parking brake every day will stretch the cable over time.
#10 |
![]() Drives: audi Join Date: Aug 2015
#11 | |
![]() Drives: Red V8 Join Date: Jul 2014
Live Hard, Drive Fast, Die Free. 'Merica
