Old 08-06-2015, 09:56 AM   #1
SunnySideUpII
SunnySideUpII's Avatar
Drives: 2015 ZL1 Bright Yellow
Scratch on Splitter
I have a scratch on my front splitter which I believe happened when I dropped my car to the dealer to be serviced. It looks like the technician must have dropped a tool on it or something. Its apprx 3 inches long, not too deep.
If it was the body, I would have some idea about how to go about repairing it. However since it is the plastic part, not sure what can be done.
Sent pics to the dealer and they accepted it was a fault their end. Waiting for them to come back to me with a solution.
I guess the best case scenario is (unlikely) to have the entire piece replaced. Alternatively they will probably offer to fix it for me.
I just wanted to know at this point if any of you has experience in repairing of scratches on a plastic part like this?
What methods can be used?
Thanks!
SunnySideUpII is offline   Reply With Quote
Old 08-06-2015, 10:09 AM   #2
sgt2410
Drives: 2015 Camaro ZL1
Mine had a scratch on it when I bought it. Dealer said they would never be able to match the matte finish. They replaced the entire splitter. You have to take the front bumper cap off to replace it.
sgt2410 is offline   Reply With Quote
Old 08-06-2015, 10:11 AM   #3
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
I do not think that there is a reasonable way to remove those scratches from that textured plastic.
At least the scratches are very minor, though.
I have already replaced the entire piece once, because it gets regularly dragged across pavement, usually going into driveways.
If you drive your car a lot, worse things are going to happen to it.
ZL1 Camaro - Worlds Largest Sports Car
Road King - Not Garage Queen
2014CamaroZL1 is offline   Reply With Quote
Old 08-06-2015, 11:33 AM   #4
Emvici
Drives: 2014 ZL1 White Convertible
I had a fairly good size nick in mine, and I tried a little jb-weld (as a filler because I didn't have any bondo around ), then some light 150 sand paper, and flat black or satin (cant remember) and you cannot tell that it was repaired. worst thing that can happen is you aren't satisfied and you replace it , like you would have done anyways.
seriously worked very nice.
Emvici is offline   Reply With Quote
Old 08-06-2015, 01:07 PM   #5
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
the part is only around $100 so better to have it replaced
cybercoaster is offline   Reply With Quote
Old 08-06-2015, 02:41 PM   #6
Garrett Custom
Garrett Custom's Avatar
Drives: 2012 Camaro ZL1, 2000 Silverado LT
I just replaced mine a little bit ago and took a whole of pictures. The pictures and how I did it are on the ZL-1 Exclusive Facebook page. It's very easy, hardest part is jacking up the car.
v/r
Roger
2012 ZL-1 #1076
2016 Explorer XLT (wife's)
2002 Ducati ST4S
2000 Silverado LT
1995 Triumph Daytona 1200
Garrett Custom is offline   Reply With Quote
Old 08-06-2015, 10:35 PM   #7
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Try heat gun just be patient and dont overheat and start a sag. You are far enough from the paint to not worry. Clean it well before you start.
ZMEnow is offline   Reply With Quote
Old 08-07-2015, 05:22 AM   #8
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
Unfortunately this part is a routine replacement item. I have bumped mine on parking blocks at stores, my friends driveway and the road when exiting businesses. People have demanded lower cars and this is the end result of that. I realize that you didn't bump your car splitter while driving for this particular damage, but you will. It will just be a matter of time. It bothered me too, with only 600 mi on mine when my first splitter damage occurred, but this is ZL1 life!
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 08-07-2015, 08:16 AM   #9
SunnySideUpII
Thanks all...
Yeah the scratches are not too bad, but they are big enough to make me notice them every time I'm in close proximity to the car. lol.
Also, as it's caused by the service center and was not my fault, it is harder to accept living with them... And I will not.
So most likely the dealer will offer me to replace it once they realize there is no proper way of bringing it to its original state.
I just have this weird thought that a replaced item as big as this, will not be as precisely flush, stable and strong as the original factory built item. Even if the dealer installs it...
I feel like sticking bandaid on it. lol
Old 08-07-2015, 08:41 AM   #10
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
put some of the "back to black" type treatment from Mothers and leave it alone. It is guaranteed to get scratched again.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 08-19-2015, 07:06 AM   #11
SunnySideUpII
Yeah I tried trim detailer from meguiars and it kinda helps a little.
When it comes to the scratches though, bottom and side scratches are I guess inevitable in long term, however scratch on "top" of the splitter is unusual and should be easy to avoid with some good old obsessive care.
Old 08-20-2015, 12:15 AM   #12
Murder 1
Murder 1's Avatar
Drives: 2013 Chevrolet Camaro ZL1
My guys at PowerTech sell car products. They had a product called "Bumper Restore" that they make for Maher Chevrolet and Dimmitt Cadillac. I had hit something that was apparently concrete in a roadway at night that was pretty bad. It went under the car and lifted up the r/r tire. There was a FAR more serious mar on the r/f corner. Between them and my detail guys I managed to go to a car show 3 days later and win a trophy so obviously the product awesome.
However it is so volatile it can't be kept in sunlight or stored in the trunk of the car like tire shine, fix a flat, spray on waxes etc. I was amazed. Surely other GM dealerships have industrial level chemicals made for them.
Murder 1 is offline   Reply With Quote
Old 08-20-2015, 12:42 AM   #13
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
That's a real bummer.
new ones are less than 200 dollars. Not sure what shipping would be though.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-20-2015, 01:21 AM   #14
SunnySideUpII
Since the damage was caused by the dealer, I'm pushing them to replace the entire piece for me. I'm not gonna pay dollars for someone else's mistake.
I'll look up this product called Bumper Restore.
Thanks.
scratch, splitter
