![]() Drives: 2011 SS LS3 Join Date: Nov 2014
Abnormal front tire wear
I searched and couldn't find anything..
Do any of you experience weird front tire wear and noise? I ask because I have went through 2 sets of front tires in 47k miles. They have not been completely worn down, just bad wear on the inner most tread blocks(pirellis). This causes crazy road noise due to the what I call "cupping" style wear on the inner treads. I am going to buy a new set of fronts next week, so have any of your experienced this issue, if so is there a solution so that I don't destroy another set in 10k miles? I am guessing it is from negative camber but my car is all stock suspension so whatever camber is there is factory. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
When you say inner treads, do you mean the innermost part of the tire (closest to the car), or the middle of the tire? I am guessing the innermost part is what you mean.
![]() Drives: 2015 2LT/RS Vert Join Date: Mar 2015
Typically inboard wear is caused by "toe-out". Cupping is usually caused by worn shocks.
At a minimum I would check the alignment. The factory doesn't always get it right.
Mel
2015 2LT/RS 'Vert, RRM/Blk Designated Airworthiness Inspector; specializing in Amateur-Built and Light-Sport Aircraft. USAF Vet. <n168tx(at)flytx.net> |
Yeah by" inner most" I meant the section closest to the engine. I had it aligned several months ago and all was in spec. It has worn tires since new in the same manner.
Thanks for the explanation. I have to say I have never worn a set of performance tires out on the inside before the outside before, and if alignment has been checked as you said, I am lost.
#6 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
36 cold tire psi right? Suspension, alignment, some thing is not right. Get it all checked out by a good dealership or shop that does good quality work.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
#7 |
And after you know everything is right... rotate your tires (side to side only for the Pirellis) every oil change or 5K miles. It will make a difference on how they wear.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#8 |
376 cubic inches of fun
This is not normal. If you don't rotate the tires side to side, you will get some cupping, but the outsides will be more worn than the insides.
Your alignment is not good. Who did it and did they give you a readout when they were done? Or did Bubba at the gas station do it? |
#9 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Could be that wherever it is within spec still isn't the greatest match for your driving. How hard do you take corners? On average here, not how hard can you once in a great while. Much hard braking? Mostly highway or mostly not highway? Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
#10 | |
![]() ![]() ![]() Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
Meh
#11 |
MY SS is SOLD
Stock SS Pirelli's are not directional tires. I have been rotating side to side since car was new. My owners manual recommends it.
#12 | |
Having said that, the 2010 manual says not to rotate them, and later manuals say yes do it, for the same tires! Anyhow, I didn't rotate. The fronts are a bit cupped and therefore noisy after 47,000 miles, but the rears look very evenly worn. However, they're now over five years old and will be replaced in the Spring of 2016 regardless of tread wear. |
#13 |
![]() Drives: 2012 Chevy Camaro SS Join Date: Jul 2015
I had the same thing happen to my 2012 ss. Cupping on the outside and really wore down on the inside. I bought the car at 13k miles and now have 23k that I put on it in six months. I switched out my tires and wheels from the 21" to a 20" because they are way cheaper. I just got them put on today. I hope I don't have the same problem again. Sorry I can't help you out, just wanted to let you know that you aren't the only one having that issue.
#14 |
The alignment was done at a general auto repair shop (not sure if his name was Bubba) lol
They did give me a print out, that my wife saw fit to throw in the garbage a few days later. If my memory is correct, I had some negative camber but it was in the range of acceptable. I just had new fronts put on yesterday so I will carry it to the dealer next week to have the alignment checked again. On a side not I had a '13 5.0 that did the same thing to Perelli fronts. 2 alignments later the dealer just told me that the negative camber was factory set (no adjustment) and that it was just going to chew up tires...and basically learn to live with it. (gotta love Ford dealers). My driving style is aggressive, but 95% of the time its just 75 mph and straight on a nicely paved 4 lane to and from work about 200 miles a week. |
