Old 08-07-2015, 07:16 PM   #1
Jake0021
Jake0021's Avatar
Drives: 2013 Ashen Gray 2SS
New tires and traction control
So I was on my way back from the shop that mounted my 315 invos, cruising about 70, gave it a lot of gas and the car surged for a half second and the traction control light started blinking. Why is this? There is no way I could spin them from 70 with a stock l99, I couldn't even do that with my bald pzero 275s.
2013 Ashen Gray 2ss L99, 20" Giovanna Shaki, 315/275 Nitto Invos, Texas Speed 1 7/8'' Headers, Lingenfelter Axleback Dyno tune by PowerFab, Black Heritage Grill, Oracle Afterburners 2.0 P13W fogs with DTRL harnesses, Night Owl Halo kit, Cold Air Inductions Intake, Lingenfelter Axleback Phastek rear blackout kit
Jake0021 is offline   Reply With Quote
Old 08-07-2015, 07:23 PM   #2
mar10
mar10's Avatar
Drives: 2010 SS RS
If it's a brand new tire they have a coating on them that causes them to be slippery at first. The coating helps remove them from the mould. It's why when you get new motorcycle tires they tell you to take it easy for the first 50 miles or so. Could be that.
Or maybe they didn't relearn your tire sensors properly.
Stainless Power Longtube headers, off road mids, stock H pipe, flowmaster mufflers, Vararam tune model intake, NightFury cam, and 91 octane email tune from Dynosteve @ rdpmotorsport.com. 473 rwhp and 430 ft. Lbs. @3,235 ft elevation.
mar10 is offline   Reply With Quote
Old 08-07-2015, 07:44 PM   #3
KR4545
KR4545's Avatar
Drives: 2012 2SS
Ive had wheel spin at those speeds, but only in the winter when the pavements like -10 degrees.
KR4545 is offline   Reply With Quote
Old 08-08-2015, 06:49 AM   #4
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Originally Posted by mar10 View Post
If it's a brand new tire they have a coating on them that causes them to be slippery at first. The coating helps remove them from the mold.
This ↑↑↑
Most new car owner manuals specifically mention giving new tires a couple hundred easy miles to break them in.
Brand new replacement tires should be given the same treatment.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 08-08-2015, 10:29 AM   #5
Scott@Bjorn3D
It is the Throttle Controller. Turn off traction control and do it and you will see the car pull like crazy and no bogging. You have your setting to high for the amount of air coming in.
I had mine a 7 and the car kept kicking in the nannies and bogging. Went to 6 and it was better but could bog it in 3rd at 55. 5 is the best setting they told me with my mods to have.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-08-2015, 01:18 PM   #6
seven
seven's Avatar
Drives: 2015 Camaro RS 2LT AGM
Similar thing happened to me the other day when i got new tires. Car slid all sideways and traction lights a going. It was raining out when I drove her home from getting them on. I was feaking out but then I was told they are new so that could happen due to the coating on them and being new.
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions)
seven is offline   Reply With Quote
Old 08-08-2015, 04:32 PM   #7
Norm Peterson
Or maybe an appropriate speed for brand-new tires . . .
Norm
Old 08-08-2015, 04:39 PM   #8
Jpnyhc1le
Jpnyhc1le's Avatar
Drives: 2013 camaro 1ss 1le
i had same issue with my r888 315s for the first 100 miles or so, now they stick like glue
Jpnyhc1le is offline   Reply With Quote
315s, control, invos, l99, traction
