Old 08-10-2015, 06:06 PM   #1
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Fried wiring harness?
Ok, about 8 or so months ago the car started kicking out random codes and i found the main harness that runs down the 2,4,6,8 passenger side of the motor. The harness was laying on the header tube and had some burned wires and the wrap was burned thru. I did my best to re electrical tape the wires that were exposed and re wrapped the harness and zipped it out of the way.
Well driving home friday in 110 deg heat, i got on it with min boost, 6psi, (CO2 bottle off). I wasn't even boost and in 3rd at about 5000rpm car fell on its face and quit and eng lite was on, P0010 and P080c codes.
Codes were camshaft position actuator solenoid circuit andUpshift / Skip Shift Solenoid Control Circuit Low were the codes.
I coasted the car off the main road and tried to start and noticed with key on the fuel pressure indicated less than 10psi (Squash return system). Car fired up for a bout a second then died, cleared codes and did it again. fired right up then died.
After about 5 attempts the fuel pressure was now at 0 and no noise from the pump at all.
I cut open the wiring harness and noticed about 4-7 wires fused together. The pic is after separating them.
So calling the experts. I imagine my ECU may be dead. I dont get any codes anymore when trying to start and it wont even fire at all...duh, no fuel.
Main concern is the large diameter black wire was the one with lots of burned plastic on it. Also kind of weird that it connects with a thinner beige wire with the black stripe. Also you can see a number of pretty scorched exposed wires.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 08-10-2015, 08:13 PM   #2
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
make repairs to the wires as needed, at minimum rewrap the wires. if they were burned bad enough may need to replace at least that section of wire. check all related fuses and hope it was just a fuse that popped before the ecu or anything else was damaged
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 08-10-2015, 11:52 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Hardly an expert, yet if you can clear your codes, I am assuming you're able to communicate with your PCM.....In that case, I would suspect it to be fine. You may want to open your harness up a little more to see if more wires are exposed.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 08-11-2015, 01:07 AM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I'm pretty sure the tan/black wire is the High Speed GMLAN Serial Data Bus +
that goes to the ECM X1 73 Pin connector.
Not that that really helps. I'll look at my harness tomorrow when I'm home and see if mine has the black piece in the middle of it. Any chance the black piece is a piece of heat shrink from a former repair?
Old 08-11-2015, 05:37 AM   #5
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Definitely got a problem there! I'd cut out all the burned, scorched wiring and replace it. As to the tan/black wire and black wire, it could be a fusible link. It's hard to tell from the picture. In any case, separate all the wires, insulate each wire, then re-wrap the bundle......and keep away from heat sources LOL!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 08-11-2015, 10:24 AM   #6
BullF-16
BullF-16's Avatar
Thanks for the replies. My main concern is why the 0 fuel pressure and no sound at all from the pump. I havent gotten around to checking fuses etc its been too damn hot here in Tx lately.
Old 08-11-2015, 01:01 PM   #7
1KillerSS
1KillerSS's Avatar
After seeing that birdsnest I wouldn't be surprised to find more than one fuse spent. Can you put power to the pumps, with something like a power probe, and see if they will pump manually?
Build thread
Old 09-07-2015, 10:26 AM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Popped a P080C today and was locked out of 2-3 continuously. CAGS has been disabled in my tune for 3 years.Checking harnesses now. Bull, what else did you find?
Edit....
Found main harness on front by #2 going down melted by header. Must have been too close since I had the engine swapped last winter. Tried to get a pic but no joy. Barely melted the wires and CAGS wire must have grounded at the header.
This thread sure helped me find it though.
Glad I caught it before a disaster happened.
Iam Broke is offline   Reply With Quote
Old 09-07-2015, 11:35 AM   #9
BullF-16
BullF-16's Avatar
Edit....
Good deal! We found the fuse to the fuel pumps partially popped. Repaired the harness and wrapped the crap out of all the wiring. When i originally found the problem with the harness a year ago it was laying on the #4 header tube. Plus a bunch of other stuff since i had it down at my shop SNLPerformance/Monster Clutch.
Seals were leaking in the rear end so GForce sent out new seals/bearing for free. Installed Outlaw 1500hp axles in place of the 1000hp set
Installed an AIS 4 gal Meth tank and new Alky meth pump (was leaking). The AIS tank is very nice compared to the tank Julio sent me with the meth kit.
installed an Improved Racing low profile oil cooler thermostat. Running without a thermostat was a pain during the winter.
Old 09-08-2015, 05:43 AM   #10
Iam Broke
PHAT B33
Iam Broke's Avatar
Mine had ~5-6 wires insulation fused together from the heat laying up against the header. Only one that melted through the insulation was the CAGS ground. All repaired now.
Old 05-27-2016, 10:42 AM   #11
MonSSterMaro
MonSSterMaro's Avatar
Drives: 2010 Camaro 1SS Inferno Orange
How did you repair your wires?
I was thinking of cutting out sections and using but connectors.
Sent from my SM-N920P using Tapatalk
MonSSterMaro is offline   Reply With Quote
Old 05-27-2016, 11:19 AM   #12
fif_gen_powa
I would recommend to solder and heat shink wrap all connections
8.3@164
Old 03-22-2019, 02:24 PM   #13
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
I know this is an old thread but wanted to say thanks for sharing this Bull. I experienced the same thing yesterday with check engine light and a bunch of codes. Found my harness touching the header and it had melted through. I am in the process of unwrapping the tape that is glued to the wires and pulling the melted wires apart. What a pain. So far, I've found 6 wires that need repair and one blown fuse. I hope to get this done in the next week or so. I am afraid that the damage to the harness may have gone further than I can easily access and if this doesn't work, I might look into replacing the whole harness... what a mess
PepeLePew is offline   Reply With Quote
Old 03-22-2019, 02:25 PM   #14
PepeLePew
PepeLePew's Avatar
here are some pics of my mess
