Old 08-12-2015, 07:16 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Fuel pump access panel??
Has anyone made one so you don't have to drop the tank? My car is gutted and being caged so cutting a hole to get to the fuel pump don't bother me.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-12-2015, 08:03 PM   #2
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
yes. I did it. Go slow and use a cut off wheel. I used weatherstripping and surrounded a square panel with a latch on one side and a hitch on the other to keep it down. Works like a charm and was WAY easier than taking my rear cradle out.
DaFisch is offline   Reply With Quote
Old 08-13-2015, 12:58 AM   #3
2010_camaro
You have pictures?
Old 08-13-2015, 03:15 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Here is how I cut mine out.
http://www.camaro5.com/forums/showpo...71&postcount=1
I used Metal ducting tape and a shaped fiberglass backing to seal it back. I only cut 3 sides. I forgot to take finished pics.
Worked great.
Old 08-13-2015, 03:17 PM   #5
Merc
In The Circle
Merc's Avatar
Worked great.
Seen it before, thought to myself that PQ is on the ball. I may take that route one day.
Old 08-13-2015, 03:25 PM   #6
PQ
Booooosted.
PQ's Avatar
The way I sealed it is easy to remove but not exactly idea as far as removing and replacing easy like a bolt in panel would be. But still WAY better than dropping the tank.
Old 08-13-2015, 05:31 PM   #7
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
Worked great.
Sweet! Thanks for sharing a really good idea. If I ever need to change my pump, this is exactly what I will do. Chevy should've made an access panel at the factory.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 04-05-2021, 03:20 PM   #8
Tool131
Tool131's Avatar
Drives: 2010 Camaro SS2
[ATTACH][ATTACH]Name:  thumbnail_20210404_174041.jpg
Size:  150.2 KB[/ATTACH][/ATTACH]
2010 2SS M6, Procharger, 8 rib, 12lbs, E85, Holley intake W/ fuel rails, TSP Blower cam 229/242 w/springs, Harden pushrod, FIC injectors, DSX Aux. fuel, Kooks long tube headers, xpipe, no cats, Mcleod twin disc, G Force Axles, DSS aluminum drive shaft, Detroit Trutrac, LPW dif cover w/BMR bushings, BMR Toe rods and Trailing arms, 5 Stars, M.T. E/T Streets, Hurst short throw, Mighty Mouse catch can, 702 WHP on Mustang Dyno 10.7 1/4 Mile
Tool131 is offline   Reply With Quote
Old 04-05-2021, 03:44 PM   #9
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
They sell a kit with a door for this. I have it in mine.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-05-2021, 04:03 PM   #10
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Link?
Deftones is offline   Reply With Quote
Old 04-05-2021, 04:18 PM   #11
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
https://www.jegs.com/i/Allstar-Perfo...WrXShDRzyJ4Tg#
Could always do something like this.
SSEssence is offline   Reply With Quote
Old 04-05-2021, 05:02 PM   #12
TheFlyingBananaSS
I got mine from Grainger.
Old 04-05-2021, 05:50 PM   #13
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Getting ready to do this myself. What did you guys use to make the cut? I was going to use electric shears if they will fit
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 04-06-2021, 02:38 AM   #14
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
I used one of these https://www.summitracing.com/parts/tnk-ad-66
Stubbsy is offline   Reply With Quote
