Old 08-13-2015, 04:17 AM   #1
PretzelKing
PretzelKing's Avatar
Drives: 2014 Camaro 2SS/RS M6
Start-up Trouble / Double Rev
Hey, all
A few weeks ago, I noticed that when starting my car completely cold, such as having sat overnight, the car seems to hesitate for a couple seconds before the car goes into its normal start-up idle. I've had the car for several months, but just noticed it recently. I don't know whether I'm being paranoid, or there is a problem. Because it only happens when the engine is completely cold, I'm reluctant to try to explain it to the dealer.
I wasn't able to find any other posts on the forum that exactly mimic my problem. The car hasn't failed to start or died after starting like many others seem to have experienced, nor has it thrown a CEL. I uploaded video to YouTube of the problem.
EDIT: I forgot to describe it in detail since it was already on the YouTube description. When the car first starts, the engine revs to 1500~ RPM or so, then begins to fall like normal until about 1000 RPM where it holds for a second before revving again back up to 1250~ RPM. The RPM then slowly fall down to idle.
Thank you!
PretzelKing is offline   Reply With Quote
Old 08-13-2015, 09:48 PM   #2
Lndryguru
Drives: 2013 Camaro 2SS/RS
my 2013 ss does run little rough and feels like its rocking when the engine is cold i dont drive it alot. When its warmed up its smooth
2013 Camaro SS Victory Red/Black Stripes
Lndryguru is offline   Reply With Quote
Old 08-17-2015, 03:11 PM   #3
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
Mine does that too, I guess I thought it was normal and part of the engine start process. I've also noticed the same issue when coming to a stop when I engage the clutch. hum, I wonder if this IS and issue.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 08-24-2015, 12:26 PM   #4
1LEdabeast1LE
Nic@Night
Drives: 2015 Camaro 1SS/RS 1LE
My 15 1LE has done this since I drove it off the lot. I had it checked out, they said normal voltage, I say bs
Sent from my Z970 using Tapatalk
1LEdabeast1LE is offline   Reply With Quote
Old 08-24-2015, 12:35 PM   #5
flamandj
I love me some Chevy's!
flamandj's Avatar
Drives: 14 2SS/RS ,14 BMW X3 ,02LR Disco 2
I have a 2014 L99... However, I let the fuel pump fully pressurize ( and let the fuel indicator reach its fuel level ( whichever It may be) and then I start her up. I did notice it starts easier and no hesitation at all. Again, it may be different on the LS3s...
Did i mention i love this car! ok good, just wanted to make sure....
flamandj is offline   Reply With Quote
