![]() Drives: 2011 blk SS Join Date: May 2012
Do your own programming via laptop
Anyone know how or what type of program which allow you to program your car yourself on a laptop thanks in advance
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 ZR1 Join Date: May 2010
HPTuners or EFI Live
![]() Drives: 2014 2SS/RS L99 Join Date: Aug 2015
![]() Drives: 2010 Camaro Join Date: Oct 2014
You gotta start somewhere. Download the efi live software and look at some tunes and tinker around with that. If your prepared to spend hours reading before you attempt to make any adjustments than go for it. But beware its not 5 minutes and its done. Lots of time goes into it especially starting out speaking from what experience I have.
2010 2SS LS3 228/235 Cam Motion custom ground cam, AI 280cc ported heads, Dynatech 1 7/8" long tubes, catless mids, CAI intake, ATI 10% UDP, CORSA cat back, Slp 160 tstat, gm 3.91s/Tru trac, EFI LIVE tuned by myself
#6 |
Too much is never enough!
HPT or EFI live. But like stated, if you don't already know.......Before you go spending money on anything, or should I say, before you go plugging in your laptop. You will want to spend about 6 months reading and reading on the internet, talking and asking questions to people on forums. And then reread everything you read before two or three times again.
I worked for years in a shop that tuned foreign cars, not to many domestic but when I started with HPT I was completely lost. Its not like a video game where you just press a few buttons and boom your done. If you do spend the time to do the research and invest in the software, feel free to hit me up for any questions. If I can help I will. I wouldn't call myself a tuner, and I would not be your first choice to tune your car.....lol. But I know enough to help you find the answers to the questions you will have.
