Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 08-13-2015, 10:41 AM   #1
jgonz007
Drives: 2015 Camaro LS
LS Fog Light installation and VA inspection
I just purchased a new 2015 2LS. I have ordered and received a fog light kit from Phastek and am ready to install it. I've been told that Virginia Law will require that the fog lights shut off when the high beam head lights are on or it won't pass inspection. Has anyone had fog lights installed on an LS and had their car fail Virginia Inspection?
Would a switched system from Gen5diy allow it to pass even though it is manual switched and not automatically switched off when the high beams are on?
Thanks for any assistance.
Jon
jgonz007 is offline   Reply With Quote
Old 08-13-2015, 12:22 PM   #2
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Jon
It wont pass on a manual switch, has to be wired into low beam switch
1fast is offline   Reply With Quote
Old 08-13-2015, 01:56 PM   #3
jgonz007
Thanks for the response. I figured as much.
Jon
Old 08-13-2015, 02:24 PM   #4
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
I had that discussion when I lived in VA and had a Jeep. It has to automatically disable them with high beams. You can still have them manually switched on, but you'd have to add a circuit to disable with high beams.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Old 08-13-2015, 02:29 PM   #5
94tagt
Drives: Pontiac Trans Am
You can try this: Remove power and say they are decoration only.
94tagt is offline   Reply With Quote
Old 08-13-2015, 03:47 PM   #6
VTSummit
nope. if they are there, they must work. you'd have to remove them if they dont work OR fix them.
Old 08-27-2015, 04:11 PM   #7
SilverMike
SilverMike's Avatar
Drives: Silver 2011 Camaro
Any reason why they must turn off when the high beams are on?
SilverMike is offline   Reply With Quote
Old 08-27-2015, 04:30 PM   #8
manganos
Drives: Lexus IS250 and BMW R1200GS
http://law.lis.virginia.gov/admincod...70/section160/
Section 10 H
manganos is offline   Reply With Quote
Old 08-27-2015, 06:39 PM   #9
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
They can be there for decoration. Just remove bulbs for inspection.
IMPERIALBLUE2SS is offline   Reply With Quote
Old 08-27-2015, 07:34 PM   #10
manganos
Bulbs , socket and wiring
Old 09-02-2015, 10:36 AM   #11
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
Even after-market equipment has to be in proper working order at the time of inspection.
GrandAmGT is offline   Reply With Quote
Old 09-02-2015, 12:57 PM   #12
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
Gen5diy can make you a harness to do whatever you want them to do. He made me one that made the fog lights the running lights, stay on with the lows, and turn off with the highs
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 09-02-2015, 03:09 PM   #13
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
This...
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 10-18-2015, 10:00 PM   #14
Tbar
Tbar's Avatar
Drives: Silver 2012 LFX
I had an accident last Jan. Needed a new front bumper, headlight, & qtr. panel repair. Knew a guy that could do it cheaper and do some upgrades like install fog lights with the money I got from the insurance company. Not much fog around here just didn't care for those blank panels of the LS. He had my car for a week and I needed it back so I took it with the bulbs/housing installed but the wire harness had not come in and he would finish it up a little later. Unfortunately he was having some health issues and unexpectedly passed away before it was completed. Couldn't locate the harness at his shop and just figured I didn't want to buy another one when I wasn't to concerned about them being operational anyway. Had the inspection due this month and knew if they were there they must work. I just plastidipped them so it looks like the original blank panels and had it inspected couple days ago. Not sure if I want to go thru this every year or just order another harness.
Tbar is offline   Reply With Quote
