LPE Dual Pump HPTuners
I have a LPE dual fuel pump installed in my car. This pump requires a remapping of the fuel gauge to properly read how much gas is in the tank.
When my car was previously tuned with SCT, a tuner had already created the mapping, so the gauge worked properly. I have since then had my car dyno tuned and switched to HPtuners. Since that time my car now runs out of fuel when the gauge reads just under 1/4 tank even though the tune was adjusted to account for the different fuel pump and mapping. I had another tuner also look at my tune and he said what i show matches what they have as being correct data, but again my gauge is still off. I am trying to narrow it down to see whether or not my sending unit went bad or if its the tune. Does anyone here running HPtuners and a LPE fuel pump have a properly working fuel gauge. If so, could they either look at my tune, or send me a copy of their tune for me to look at?
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno. |
Too much is never enough!
I don't have LPE dual pumps, but I know that LPE have different resistance values VS gallons in the tank. I would give Lingenfelter a call and ask them. BullF-16 went through your exact same problem. I dont know what he did to fix it. I think Bo White is also using HPT and LPE pumps, may want to send those guys a pm.
Correct, LPE does use different resistance values. Lingenfelter was useless. I contacted them and all they said was we only tune for EFI Live. Terrible customer service. It took days for them to just tell me that.
I have already been in contact with Bo, but he doesnt have a file off hand he can send to me. Basically just looking for someone that is running HPTuners with the LPE pump that has a properly working gauge. If they do, can they send me their tune file so i can compare. I had one other person look at my file and they said my numbers look correct, but still having gauge problems. I want to double and triple check everything so i can try and narrow down this problem. Thanks,
2010 1SS/RS LS3 M6
#4 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
We have seen sender failures and connection problems with this system and it's installation. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
Ted,
I believe the tuner started with the edelbrock tune, but not 100% on that. What kind of sender failures have you seen? Have you ran across issues where it would run out of fuel with the gauge still reading very slightly less than 1/4 tank?
2010 1SS/RS LS3 M6
#6 |
Did you ever get the calibrations? My tuner did my dyno tune and couldn't get the values correct for the fuel gauge. He also uses hp tuner and lingenfelter told me the same thing.
5.98 @ 115mph
#7 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
I have a properly operating fuel gauge with the LPE twin-pump installed. Shoot me your tune and I'll look it over.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
