Old 08-14-2015, 06:21 PM   #1
1LE Timmy
1LE Timmy's Avatar
Drives: 2014 1SS 1LE
Question about going back to stock.
Have a camaro at my shop that has long tubes, high flow cats, and CAI. I'm assuming it's been tuned for the mods as well.
Has anyone gone back to stock but left the tune in? Would it cause any drivability/CEL concerns?
1LE Timmy is offline   Reply With Quote
Old 08-17-2015, 06:55 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Why are you assuming its been tuned? You would be surprised at the amount of people who do the bolt ons and not get a tune. Most are worried about PCM tuning and it voiding the warranty, so they don't do it. Others just don't know that they should have it tuned. They don't do the research to find out.
As for the issues with no mods and tune. You may not have drivability issues, but your fuel trims will be off to say the least.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
