08-16-2015, 02:38 PM | #1 |
2 questions about my new Camaro
1) there isn't a nice portfolio/folder for the owner's manual & such? My Pontiacs came with nice leather ones.
2) what does the build sheet look like? I believe I have it but there isn't as much info on it as my '02 Trans Am's sheet. Would someone post a pic of a Camaro build sheet? Thanks.
2015 Camaro 1LE
2009 Challenger R/T 2007 Solstice GXP 2004 Colorado ZQ8 2002 Trans Am WS6 Collector Edition 1999 Blazer 1994 Grand Prix SE B4U |
08-17-2015, 11:24 PM | #2 | |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
2. A build sheet e-mailed to me when I was 1LE shopping (NOT my 1LE). Vehicle Information VIN: 2G1FJ1EW8F91xxxx Model: 1ET37-2015 CAMARO 2SS COUPE Branded Title: No Warranty Block: No PDI Status: Yes Order Type: 70 - RETAIL - STOCK Field Actions: 0 Open Vehicle Build Model: 1ET37-2015 CAMARO 2SS COUPE Order Number: SFDDQV Build Date: 12/04/2014 Build Plant: 9 Option Codes *IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker. 01A - SEAT TRIM JET BLACK 1AS - DR PANEL GRAPHITE SILVER W/ ICE BLUE PIPING 1LE - SS 1LE PERFORMANCE PACKAGE: * UNIQUE REAR SPOILER * SUSPENSION RIDE AND HANDLING PACKAGE * AXLE, 3.91 RATIO * SUEDE SHIFT KNOB * 6-SPEED MANUAL TRANSMISSION * SUEDE STEERING WHEEL * TIRES, BLACKWALL * WHEELS, 20" ALUMINUM 1SZ - OPTION PACKAGE DISCOUNT 2SS - BASE EQUIPMENT PACKAGE 3CJ - MOLDING I/P GRAPHITE SILVER, POLYCARBONATE 4AA - INTERIOR TRIM JET BLACK 5A7 - TIRE SEALANT AND INFLATOR KIT (IN PLACE OF SPARE TIRE) 6X1 - COMPONENT FRT LH NON-COMPUTER SEL SUSP 7X1 - COMPONENT FRT RH NON-COMPUTER SEL SUSP 8X2 - COMPONENT RR LH NON-COMPUTER SEL SUSP 9L3 - TIRE SEALANT AND INFLATOR KIT (IN PLACE OF SPARE TIRE) 9X2 - COMPONENT RR RH NON-COMPUTER SEL SUSP AE4 - SEATS, FRONT SPORT BUCKET AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN AFM - BLACK AKQ - PWR SEAT ADJUSTER, FRONT PASSENGER, 6 WAY AL0 - SENOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AMM - PWR SEAT ADJUSTER, DRIVER 6 WAY W/ PWER RECLINER AT8 - RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING ATG - REMOTE KEYLESS ENTRY AX2 - KEY COMMON AXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN AXJ - PASSENGER CAR AY0 - AIRBAGS, DRIVER & FRONT PASS. FRONT / SIDE IMPACT AIRBAGS - SIDE HEAD CURTAIN B34 - FLOOR MATS, FRONT B36 - COVERING FLOOR MAT, LUGG COMPT. B56 - MOLDING ROCKER BODY COLOR BD8 - MOLDING BODY-COLOR ROOF DITCH C67 - AIR CONDITIONING C93 - LAMP INTR, AMBIENT D52 - UNIQUE REAR SPOILER D75 - OUTSIDE DOOR HANDLES DBX - MIRROR, INSIDE REARVIEW AUTO DIMMING DCP - ONSTAR PROCESSING DIRECTIONS & CONNECTIONS DD1 - POWER OUTSIDE MIRRORS DRIVER SIDE AUTO DIMMING DNS - DEALER INSTALLED INDICATOR EAL - SEAT TRIM, LEATHER APPOINTED FRONT SEATS EF7 - COUNTRY CODE, U.S.A. FCR - TRIM DOOR LIGHT PIPED BACKPAINTED FE6 - SUSPENSION RIDE AND HANDLING PACAKGE FHO - VEHICLE FUEL GASOLINE E10 G80 - LIMITED SLIP DIFFERENTIAL GAZ - SUMMIT WHITE GW1 - AXLE REAR 3.91 RATIO I15 - ENGINEERING YEAR 2015 JL9 - ANTI LOCK BRAKE SYSTEM, 4 WHEEL DISC KA1 - DRIVER & FRONT PASSENGER HEATED SEATS KG4 - ALTERNATOR, 150 AMPS KS9 - SUEDE SHIFT KNOB KTI - TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE LHD - LEFT HAND DRIVE LS3 - ENGINE, 6.2L V8 W/ SFI MAH - MARKETING AREA US, PUERTO RICO/ USVI MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - TRANSMISSION, 6-SPEED MANUAL N10 - EXHAUST, DUAL TIPS N26 - SUEDE STEERING WHEEL NC7 - FEDERAL OVERRIDE NE1 - 50-STATE EMISSIONS NU5 - EMISSION SYSTEM CALIFORNIA BIN 4 NV9 - PWR STEERING, ELECTRIC ASSIST NZL - STEERING WHEEL MOUNTED AUDIO CONTROLS OSH - OSHAWA PLANT CODE R9N - PROCESSING CODE-SEAT RKC - TIRES, BLACKWALL RSK - WHEELS, 20" ALUMINUM SBF - RESTRAINT SEAT BELT SGC - SPARE TIRE/WHEEL NOT DESIRED INFLATOR KIT REPLACES SPARE SLM - STOCK ORDERS SRM - MODEL CONVERSION CODE SRU - REAR VISION PACKAGE T3N - DAYTIME RUNNING LAMPS T3Y - FOG LAMPS, FRONT T4F - HEADLAMPS HIGH INTENSITY T83 - HEADLAMPS CONTROL AUTOMATIC ON-OFF TB8 - HEADLAMPS CONTROL RH RULE OF THE ROAD U2K - XM RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUSXM AFTER 3 MTHS U77 - ANTENNA, ROOF MOUNTED UD7 - REAR PARKING ASSIST UDD - DRIVER INFORMATION CENTER, COLOR DISPLAY UDY - COLOR INFO DISPLAY (CID) 7", WVGA, TOUCH SCREEN UE1 - 6 MTHS ONSTAR(R) DIRECTIONS & CONNECTIONS W/AUTOMATIC CRASH RESPONSE, TURN-BY-TURN NAV PLUS 5-YEAR ONSTAR BASIC PLAN (OMITS SAFETY, SECURITY & NAV) (SEE ONSTAR.COM) UFU - AM/FM STEREO COLOR TOUCH RADIO W/ 7" SCREEN DISPLAY UG1 - UNIVERSAL HOME REMOTE UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE) UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER UMQ - GAUGES, AUXILIARY UP9 - CHEVROLET MYLINK UQA - BOSTON ACOUSTICS 9 SPEAKER AUDIO SYSTEM USR - USB PORT UTJ - THEFT DETERRENT ELECTRICAL UNAUTHORIZED ENTRY UV6 - HEAD-UP DISPLAY UVC - REAR VISION CAMERA SYSTEM V8D - VEHICLE STATEMENT US VK3 - FRONT LICENSE PLATE BRACKET VRG - VAA/COMPONENT REL COCKPIT VRH - VAA/COMPONENT REL STEERING COLUMN VRK - VAA/COMPONENT REL ROOF TRIM VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION VRN - VAA/COMPONENT REL REAR SUSPENSION VRR - VAA/COMPONENT REL TIRES & WHEELS WMF - VIN MODEL YEAR 2015 WRS - RS PACKAGE: * MOLDING, BODYCOLOR ROOF DITCH * HID HEADLAMPS WITH LED HALO RING * DAYTIME RUNNING LAMPS WZY - HANDLING CHARGE FROM OSHAWA XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE XR5 - POLLEN FILTER Added Option Codes Vehicle has no current record of SAIO codes. For this vehicle: → View Vehicle Summary → Service Contract → Branded Title → Warranty Block → View Vehicle Build → View Vehicle Component Summary → View Vehicle Transaction History Detail → View Vehicle Delivery Information
2015 2SS/1LE/RECARO/NPP/RS/NAV
08-18-2015, 07:05 AM | #3 |
Drives: 2014 2SS/RS 1LE Join Date: May 2013
Get one of these at Home Depot, it fits your manuals and registration perfectly and sits in the glove box like it was meant to be there. http://www.homedepot.com/p/Husky-12-...2N11/203224009
08-18-2015, 09:04 AM | #4 |
1) OK, so, $47K for a car and no portfolio for the owner's manual. That's weak.
2) I'd like to see an actual build sheet. Not an electronic list. Can someone scan theirs in & post it?
2015 Camaro 1LE
08-18-2015, 09:52 AM | #5 |
Drives: 2010 Camaro 2LT RS, 2009 GTR Join Date: May 2009
No they do not come with a portfolio/binder book. Is that going to be a deal breaker for you? My GTR doesn't have one either, does it bother me? Not at all.
Above is basically what the build sheet looks like unless you are talking about the window sticker that is super long which has the exact same information just with pricing included.
Build thread: http://www.camaro5.com/forums/showthread.php?t=152335
Photos: www.flickr.com/bradbeer GTR Instagram: @NoCrustGTR |
08-18-2015, 11:49 AM | #6 |
Ya know, it DOES kinda bother me that you pay that much for a car and they can't include a portfolio. It's BS.
And no, the second post is NOT what a build sheet looks like. I'll scan what I think is mine in & show what it might look like. I'm just not positive what I have is the full build sheet.
2015 Camaro 1LE
08-18-2015, 12:04 PM | #7 |
I believe this is a 5th gen Camaro build sheet but I'm not sure.
This is not mine. I found this image in another thread. I'm pretty sure the dealer CANNOT print this out for owners. What I think is my build sheet looks like what's in the image.
2015 Camaro 1LE
08-18-2015, 01:11 PM | #8 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Haven't dug mine out. But they can apparently be printed. There is an entire topic about it here: http://www.camaro5.com/forums/showthread.php?t=347878
08-19-2015, 03:22 PM | #9 |
Drives: 11 2SS/RS M6 vert Join Date: Dec 2010
Yes, That's the build sheet. There are also two smaller ones that say left and right that went with the doors. I do not think these can be re-printed by anyone.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
08-19-2015, 07:55 PM | #10 | |
I have the big sheet and the 2 smaller door sheets. And I agree with you. I don't think these documents can be reproduced. That means a LOT to those that collect cars. And I think I can find Chevy portfolios on eBay.
2015 Camaro 1LE
