Old 08-16-2015, 10:13 PM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Question Red Line D6 ATF
I seem to have sprung a small leak from my external trans cooler after the Fest. Since I don't know how much I lost and I'm not sure what the shop put in when I had my stall converter installed, I was thinking of just changing it. Does anyone run Red Line D6 in a stall auto tranny??
Lnch Mny is offline   Reply With Quote
Old 08-16-2015, 10:47 PM   #2
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
As far as I know, you want D4 for your tranny.
Rico is offline   Reply With Quote
Old 08-17-2015, 10:33 AM   #3
Camarotobeornottobe
Drives: 1LE
D4 is specified for the manuals. The OP has an auto.OP, go to Redline's website -- they have an application database there that will tell you what is specified for your trans. If D6 is specified, you can feel safe using it -- Redline makes good stuff.
Camarotobeornottobe is offline   Reply With Quote
Old 08-17-2015, 12:00 PM   #4
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
D6
Yea, everyting I looked at last night said they were using the D4 in Manual transmissions. I did check the Red Line web site and D6 is what came up. Just wanted to put a post out there before I orded it.
Old 08-21-2015, 08:54 AM   #5
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I am running D6 in my auto.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
