Old 08-17-2015, 05:15 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Exclamation Need help ASAP!
I'm at the dyno with my car and we are getting bad belt slip. I'm running the 2.5 pulley on my lsa blower. It's a 6 rib. I need part numbers for a belt that will grip better.
This is a 2014 ss so it does not have power steering only power assistance.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-17-2015, 05:46 PM   #2
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Take it to the parts store and tell them you want a size smaller.
Nitroman28 is offline   Reply With Quote
Old 08-17-2015, 06:08 PM   #3
2010_camaro
It's already a inch shorter. The tensioner is maxed out
Old 08-17-2015, 06:34 PM   #4
cc-rider
Time for a better tensioner. Jannetty has one that many have praised.
cc-rider is offline   Reply With Quote
Old 08-17-2015, 07:48 PM   #5
2010SSRSM6
2010SSRSM6's Avatar
Call LPE and get their tensioner....best holding tensioner I've seen so far and I'm on # 3.
Old 08-17-2015, 08:13 PM   #6
2010_camaro
I need the part number for a green belt. I currently have a autozone belt on it. Could be the reason for slipping. Also does the tensioner work with the LSA conversion?
Old 08-18-2015, 06:59 PM   #7
2010SSRSM6
2010SSRSM6's Avatar
Check with Andy @ ADM Performance to verify that it works with the LSA. AutoZone should be able to give you the part number for the Gates Green belt based off the belt you currently have. Which part # is currently on the car?
Old 08-18-2015, 09:57 PM   #8
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I have this pulley too man, gates belt and I have belt dust all over my water pump. You really need an lsa accessory drive. I think that's the only real fix, at least that's what I'll be doing
ttshovel is offline   Reply With Quote
Old 08-19-2015, 01:46 PM   #9
2010_camaro
Can't remember the part number. It's 96“ and 6 rib. I picked up a bando belt. It's way better than the autozone belt but idk if it's still going to work.
Old 08-19-2015, 09:32 PM   #10
ADM PERFORMANCE
Drives: Anything I want
Take a picture of your belt routing,we run 2.38" with 6 rib no slip on cammed header cars.
Do you have a boost log from the dyno you can post.
ADM PERFORMANCE is offline   Reply With Quote
Old 08-19-2015, 09:37 PM   #11
ADM PERFORMANCE
Old 08-20-2015, 04:23 AM   #12
2010_camaro
I don't have any logs. I think my belt slips on my crank pulley. It's wrapped extremely well around my supercharger pulley.
Do you have any diagrams of belt routings?
