Old 08-19-2015, 01:22 AM   #1
BASSTUB
Drives: ISO ZL1
Rotor wear on 20k mile car
I'm in the market and actively searching for a used ZL1. I found a decent car with 20k miles, but uncovered that the brake rotors had already been replaced due to wear.
To me this indicates that the car was tracked pretty hard. Is that a safe assumption? Or is rotor replacement at 20k miles "normal"? What else could cause the rotors to be worn through in 20k?
The car appears to be all stock, with the exception of a catch can.
I already walked away from the deal, but the car is still available.
Thanks in advance for the info!
BASSTUB is offline   Reply With Quote
Old 08-19-2015, 10:03 AM   #2
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Go with your gut feeling. There are plenty of ZL1's available. I'm at 37K miles, track my car a good bit and do autocross and DD my car. My rotors are fine and just now needing OEM brake pads replaced.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 08-19-2015, 03:42 PM   #3
ZL1DropTop
Drives: 2013 Camaro ZL1 Convertible
I replaced my brakes at around 20k and the shop was able to turn the rotors, but said I was really close to the minimum and that I certainly wouldn't be able to turn them again. at that time I had never tracked the car either. The factory rotors don't have much extra material on them, and I was lucky I was able to turn mine once, so I would say it's not out of the ordinary to have to replace the rotors after 20k even without tracking the car.
ZL1DropTop is offline   Reply With Quote
Old 08-19-2015, 04:12 PM   #4
z28lt1
Drives: 2014 ZL1
Rotors are finicky. My daily driver SUV developed a "warped" rotor (yes, likely really uneven pad wear or something similar) within the first 5k and was replaced. While rotor replacement could be indicative of heavy track use, i don't think it is the only reason for it.
If all 4 rotors were replaced, it might be more likely track use, but still not for certain. Also, I'd say it is rare that a completely stock car would be heavily tracked, but it does happen.
z28lt1 is offline   Reply With Quote
Old 08-20-2015, 12:08 PM   #5
mrshanes
Drives: 2014 Camaro ZL1
It could have been returned to stock before being traded in.
mrshanes is offline   Reply With Quote
Old 08-20-2015, 08:42 PM   #6
BASSTUB
Drives: ISO ZL1
Thanks for the replies guys. I will be patient and wait for "the one"!
I simply don't trust this car, and it is not worth the risk.....
