Old 08-20-2015, 08:10 AM   #1
CamaroinCLE
CamaroinCLE's Avatar
Drives: 2014 CRT LT
Coolant Temp Question
Been a GM owner for over 25 years now and I have a question, I see on my 14 1LT coolant temp gauge does not run at the 1/2 way mark as all other cars I have owned. noticed this is the case with other Camaro's based on dash pictures here and other sites. Do the Camaros have a different temp range gauge?
CamaroinCLE is offline   Reply With Quote
Old 08-20-2015, 08:50 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
My Silverado runs below the center as well as my Camaro. Temp guages do change from from model to model and even within the same model over time.
Old 08-20-2015, 10:04 AM   #3
Denis
Denis's Avatar
Drives: 2010 SS
granted the SS has a different engine, but this is mine after reaching operating temp.
Old 08-20-2015, 12:51 PM   #4
TooCool5
TooCool5's Avatar
^^This^^ on the V6 also.
Old 08-20-2015, 12:53 PM   #5
CamaroinCLE
Drives: 2014 CRT LT
that is where mine is at too.. ok then this is normal and nothing to worry about then.. Thanks everyone
Old 08-23-2015, 09:44 AM   #6
italiano687
Drives: 2015 Chevrolet Camaro 1lt
My 2015 2LT has the same reading after reaching operating temperature.
italiano687 is offline   Reply With Quote
Old 08-23-2015, 11:34 AM   #7
$inferno
Trust No One
$inferno's Avatar
Drives: 94 Camaro Z28 & 2010 Camaro 1LT IOM
I use the center digital readout for the temp sometimes. Our LLT V6 stays at 190-201-203 in 90 degree heat with AC running.
2010 Camaro 1LT V6/A6
94 Camaro Z28 A4
$inferno is offline   Reply With Quote
Old 08-23-2015, 11:46 AM   #8
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
Yes. It is normal. Mine stays below the halfway point.
JLSuperfly is offline   Reply With Quote
Old 08-23-2015, 11:55 AM   #9
drew peacock
Banned
Drives: 2012 2SS INFERNO ORANGE
mine stays lower..8k miles 2013 v8
drew peacock is offline   Reply With Quote
Old 08-23-2015, 06:11 PM   #10
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
It's an electronic gauge with a "range of acceptable". Don't sweat it as long as it's not near the H or throwing an 'overheat' light or code. One of the reasons car makers don't like gauges and displays is that owners freak out over the perception of a problem when no problem exists. Don't worry that your needle isn't dead-nuts center.
As an FYI, a 15psi closed cooling system has a boil-over temp of about 247* F.
ChrisBlair is offline   Reply With Quote
