#1 | |||
![]() Drives: 2010 Thunder Grey CTS-V Join Date: Nov 2014
Maxing out an E-Force - HELP!
Quick Recap: Car is a 2010 Camaro SS named "Bad Jewel"
First round of mods circa 2010: Edelbrock E-Force, SW long tubes/exhaust, Rotofab... Made 550/550 on a Dynojet. Second round of mods July 2013: Comp Cam and upgraded valvetrain, Ported LS3 heads, ZL1 fuel pump, LS9 Clutch, 1200 HP Axles. Made 655/650 on same Dynojet. Around October or so of 2013, the car ended up being way down on power. After pulling the heads, we discovered that the number 5 piston had a piece broken out of the top of the piston. It was still holding compression though! Third round: Lingenfelter 417 Low compression stroker with forged internals, Lingenfelter dual fuel pumps, ID850 injectors, 2.75 pulley on the E-Force. Took the car to the dyno yesterday and could not keep the IAT's down at all. We put ice in the blower reservoir, ice on top of the blower, as soon as you would start the car it would already be at 130 degree IATs. As soon as the car would start to crest 4k RPM on the dyno, it would immediately pull 5 degrees of timing because the blower was running so hot. It made 590 rwhp/630tq and was 88 degrees outside with 60 percent humidity. On to my question... Would spraying Methanol injection keep the IATs down enough to make power with this set up? We are trying to keep the same blower that was on the car when we began because it is a "Tom Henry Racing" car, and we wanted to keep it as much of that as possible. Other thoughts were to pull the blower off and stick it in the crate with the stock LS3 that had cracked a piston. What blower would you guys recommend to go with that would be enough to go with the stroker motor and fuel? We have a Procharged LS3 Camaro as well that made 598 rwhp and would really like to stick with a roots style system on this car for the immediate power and not having to wait like with the Procharger for the car to really come on. Thanks for reading, lets hear some opinions. -Justin |
![]() ![]() ![]() ![]() Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
The Edelbrock heat exchanger is barely adequate at 6-8 psi on a stock LS3. I had one on my Maggie, IATs went up 10+ degrees just cruising compared to the stock maggie HX, and that was with 3 crushed tubes not doing anything, even after adding a secondary dual pass HX. Check your pump and hoses also for a restriction, make sure it is flowing well.
Too much is never enough!
Yes, do the Meth, if you want to make any more power.
Banned
Drives: 2010 Camaro Join Date: Mar 2014
Meth for sure....Id also look towards an afco he with dual fans.
![]() ![]() ![]() Drives: All things Turbocharged Join Date: Dec 2010
What were IAT's going up to on the pulls?
You did just swap to a less efficient engine, that's the right way to go when you have a lot of blower on tap like a F1x or YSi. But when you're limitation is a small PD blower, you don't drop compression and expect more power. You did gain a ton of reliability and safety margin with the new engine though. |
#6 |
![]() ![]() Drives: 2010 2SS Join Date: Sep 2012
Bigger heat exchanger for engine and blower. Bigger pump for blower exchanger maybe. Methanol for sure. Install phenolic spacer between blower and engine. Do you have cats? I would ho with a 3" pulley for less heat and longevity of blower. Less belt slip...
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
#7 | ||||
What do you guys think about running a dry shot of nitrous to cool the blower down? |
#8 |
With that psi/cube combo you need to get rid of those cats...wrap/coat headers, hood vents.
#9 |
![]() ![]() ![]() Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
Mine gets up to 134 on a long 3rd gear pull at 13 psi with meth on a 85 degree day. That's the highest I got all summer. I did add a higher flowing coolant pump on my Whipple heat exchanger.
#10 |
Do the meth first.
#11 | ||||
![]() Drives: 2011 camaro SS Join Date: Mar 2014
High IAT's
I went with a KDI Intercooler, Lingenfelter re-programmed super charger pump with 1" hoses, Ron Davis radiator and most importantly 1/2" pheneolic spacers and I significantly reduced IAT's. My next step is porting supercharger with good porting you can remove about 6 lbs of useless material and increase airflow. |
#12 |
![]() Drives: Twin turbo G8 GXP Join Date: Dec 2012
Less compression means more boost. Time for twins. What turbos would AGP recommend for this build?
#13 | |
With the advancements in turbos in just the last year, I'd have 3 different recommendations that just get better and better the more budget you're willing to invest. The premise I'd assume is that 1000whp is the max we would ever want to push since it's an aluminum block. The three options starting with good cheap turbos, would be 56mm extended tip, cast wheel, journal bearing. We've sold lots of these and had them do 1000whp across the country on many cars. Stepping up to a dual ballbearing Garrett with a billet wheel, the 55/57's will spool up noticeably quicker and still support 1000whp. And now the latest and greatest turbos available today would be the Borg Warner EFR series 7670. These measure 57mm and are a forged milled compressor wheel and a super lightweight Gamma-Ti turbine wheel, rolling on a dual ballbearing structure. These are literally Indy Car turbos. Indy cars run 22psi and no intercooler with these efficient babies. Fastest boost response available and not really that crazy expensive. |
#14 | ||
We are going to try this, along with methanol injection. Where did you put the pheneolic spacers at? Quote:
However, We are looking to start a new build once we figure this one out IE: LSX TBSS, LSX ZL1... and after browsing your guys site, you have about everything you need to put together a healthy boosted application. We will have to keep you guys in mind. I bookmarked your website.
