08-20-2015, 02:14 PM | #1 |
OWTATIME
Drives: 1969 CaRaMo Join Date: May 2009
ZL1 AC won't cut off...
The fan/ blower inside my ZL1 wont cut off. It doesn't matter if its on heat or AC. We have cut the car off and cut it back on and the fan is still wide open. 1st time this has happened. Any ideas what it could be?
08-20-2015, 02:16 PM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
What do you mean? Blower running at full speed? Or the compressor engaged and spinning?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
08-20-2015, 02:19 PM | #3 |
OWTATIME
The fan/blower inside the car is stuck wide open.
08-20-2015, 03:00 PM | #4 |
Drives: 2013 ZL1 A6 Join Date: Nov 2013
Possibly a bad relay
08-20-2015, 03:14 PM | #5 |
OWTATIME
Checked fuse box and all those are good. Cold ac blowing no matter what setting it is on and the heated seat buttons do not work either. All else is good to go. Atleast it's blowing cold air instead of heat
08-20-2015, 03:24 PM | #6 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Control, Alt, delete!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
08-20-2015, 03:29 PM | #7 |
Drives: '21 ZLE A10 Join Date: May 2012
tap each relay (not fuse) with the tip of your finger sharply...read on the underside of the plastic shield underhood which relay is the one for the blower motor and unplug it and plug it back.
08-20-2015, 04:19 PM | #8 |
OWTATIME
Thanks Stephen! That worked!
08-20-2015, 04:19 PM | #9 | |
Captain Gingerbeard
Could be a relay, could be a shorted wire somewhere, could be the resistor, could be the control panel.
EDIT: Glad it was just a stuck relay. If it keeps happening, pick up a new one. They're cheap.
08-20-2015, 05:15 PM | #10 |
OWTATIME
Thanks. I am gonna order one to keep on hand.
08-20-2015, 05:44 PM | #11 |
Let's go Rangers!
08-20-2015, 05:45 PM | #12 |
HAMMER PILOT
The way everything is computer controlled, it should be an option.
08-20-2015, 06:52 PM | #13 |
08-20-2015, 07:06 PM | #14 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
