Old 08-20-2015, 03:17 PM   #1
mcapple
Drives: 2011 Camaro 2LT
Water leak in 2011 Camaro 2LT/RS during rain
any one have this issue? rain always get in from the passenger side door
mcapple is offline   Reply With Quote
Old 08-20-2015, 03:18 PM   #2
mcapple
I guess it's bad door seal. Any idea?
Old 08-20-2015, 04:37 PM   #3
Nakam
Drives: 2010 Camaro SS/RS
Check the rain deflector inside the door, this type of leak happened to mine on both sides. The seal that holds it on isn't great and can start to peel off, i had to re-caulk mine. You can test it by removing the inside door panel and running water down the window on the outside. If the rain deflector is the issue, you should see a line of water running down along the bottom somewhere.
Nakam is offline   Reply With Quote
Old 08-20-2015, 06:51 PM   #4
mcapple
Exactly!
Thanks bro. If you come to Toronto, let me buy you a beer!
camaro, leak, rain, water
